They are screwed into the lip of the fender and secured to the outside of the body with double sticky tape.
I would vote no because I don't think they do crap. I took my front ones off because they hung too low and I was afraid of destroying my body by hitting something. I still have the rears on, but that is just because I haven't taken them off. They do keep about 2" of the truck clean, but everything else will get coated in mud just like they never existed.
they are put on with two adhesive strips and one screw through the sheet metal. Not worth it!! they fill up with mud very easily and at highway speeds they vibrate or wiggle and they will etch a line all the way through to the bare metal where the plastic contacts the sheet metal. Not good, I'm sorry I didn't rip mine off on day one!!
Galaxy Black 2004 Titan XE CC 4x4 w/ Off-Road Package, Preferred Package.
Mods: PRG Spacers, 17x9" Eagle 187s (+2mm offset) w/ 315 70-17 BFG All-Terrain KO tires, Stillen Diff Cover, Alpine Type-R components in the front, coax. in the rear w/ 50 x 4 Rockford Fosgate Amp, XM, Debadged, and Homemade RCA pre-outs on in-dash changer.
I had to ditch mine to clear my new tires...since the frt ones were gone, had to pull off the rears...see below.
PRG Performance Kit w/SAW's
Born 9/2004
i had one of mine off to replace it and there was not a scratch...maybe it was just a crappy job someone did putting them on?...didn't vibrate either...i vote for yes...i dont mind mine...no problems with them
The double sided sticky tape doesn't last. The left rear didn't stop the right edge of the "secret compartment" opening from getting chipped by rocks...they are better than going with nothing.
Here's a "Yes" vote. No problems (11k miles) and they look good against the Red Brawn color. Definitely helps to keep road grime off paint.
04' Red Brawn 4X4 LE Crew Cab
Born: 04/02/04 --- Adopted: 7/04
Utili-Track Bed Extender / Utili-Track Overhead Rack
Power Glass Sliding Sunroof / Off-Road Package with Big Tow / Side Air Bag Package /
Bug Defector / Navigation Package / LCD Monitor Info.Center / DVD Mobile Theatre System / In-Channel Vent Visors / Tinted Driver-Passenger Windows /
Splashguards, Captain Chairs
I say yes also, I have them on mine and they do help keep the mud off the sides of the truck. I had to restick one of mine the double sided sticky tape they use just doesn't seem up to the task.
I'll have to say though that loufish's truck looks nice without them.
__________________ "It is not through knowledge, but through experience of the world that we are brought into relation with it."
__Albert Schweitzer
2001 Polaris Sportsman 500.
I guess I'll be the hot-dog now and say "it depends on how you use your truck." If you think you're robby gordon like I do, then rip 'em off. If you are concerned about water spray from the tires on your "22s" then you'd better get 'em.
Wow, I am surprised that they actually do anything for some of you. In my experience, 2-3" of clean paint before the mud/road grime starts showing on the paint does not justify the $100 cost for the things. And that was prior to my PRG front & rear lift. Now that I have even more tire exposed to the paint, the flaps I still have on the rear do even less to protect the paint.
Actually, my LE had them on the truck from the factory(freebie). They do help keep the truck cleaner.
Clint
You have two choices in life:
