Old 04-14-2005, 10:09 AM   #1 (permalink)
Wire Tap for Electrical Connection
I need to know where I can find a wire to tap into that is hot only when the ignition is hot. I have a CD of the Titan system, but can't find the exact location of wires. Surely somebody here has bared a red wire and remembers where it's located <G>
TIA
2005 LE Smoke 2 X 4 CC
OK, I found the dark green wire in the fuse panel for the cig lighter, protected by a 15 amp fuse. Now I'm trying to find a way to thread a single 16 guage wire thru the engine firewall. I just looked for 30 minutes, and can find no reasonable way other than to drill a hole thru, then thread the wire, and seal the hole with goo-come-pucky.
Anybody??
Rotorheader is offline   Reply With Quote
Old 04-14-2005, 10:50 AM   #2 (permalink)
JMC
JMC's Avatar
The cig. lighter on the right side of the dash is hot with ignition only. Nissan hid the wires darn good because I couldnt anything that was accessable other than running a wire from the fuse box.
JMC is offline   Reply With Quote
