After about 100 miles of highway driving at 55-60 MPH I took some temps and the diff registered about 190 F. Made another stop after some hills and got a reading of 200 F. The readings were taken from the center and bottom of the diff cover right after pulling off the highway.
Now for the question: are the above temps ok?
Right now it's running the stock weight oil that was replaced at 3000 miles (5900 miles on the truck now with the 04 steel cover). I will make the switch to synth once I get the new PML large capacity diff cover in a month or so.
The truck did wonderful power wise and only had to downshift to 3rd a few times. On the way back there was a nasty headwind and in fourth gear the temp was rising on the tranny gauge to about 3/4. Dropping it into 3rd made the temp lower in about 30 seconds.
A great trip and yes the water is still cold!
What might an 8600# load look like you ask? Well here you go:
2004 Nissan Titan KC SE 4x4 with Big Tow package- Zoomers exhaust tip, Rear-view screen in sunglass pocket, scanguage intergrated into overhead console, power tailgate lock.
1982 Delorean DMC-12 Turbo (Vin #10696)
2000 Toyota Camry CNG Powered
1999 Forest River Sandpiper 21R 5th wheel trailer
I guess there'e no backing up for you huh? Scary thought.
I did a test backup while the rig was straight and got about 20 feet before the boat started to swing out.
This was my first trip ever with a setup like this. It was more stable that I expected and turning was no big deal. I would be fine taking this up to Shasta (a 10 hour drive each way).
You've got too many toy's. If your single, get married: if your married get divorced. Either way it should fix the problem
HAHA funny you should mention that, I just got engaged a week ago........
Dont know if this helps but here it is. I temped mine after a trip to a local lake using the same method. Mine was 165-168. My boat only weighs 4k and I have changed the oil to mobile 1 75-140.
2004 SE CC Deep Water 4x2 BT
Nismo CAI, Zoomers exhaust,PRG leveling kit, PRG traction bars,OEM step rails, Nissan fog lights, ARE LSII cover,New 2005 rear end, Active tuning grounding kit,Black powdercoated "stubby" antenna,Weather tech vent-visors (front only), Armada air dam, PIAA back up lights, chrome tow hooks, Air Lift "Ride Control" Air bags, AMP Research power steps, TrueTrac, Mag-Hytech diff cover, A-Pillar 3 gauge pod,Custom painted engine cover by Scottsbro23
Thanks for the numbers. I will let every one know what happens with the new cover and oil.
Yes it is leagal in CA if you have your Commercial DL with the doubles endorsement, which I just got. Many other states too, some with no special requirements.
Don't give up on backing up with two trailers. My buddy is a farmer and he can back up two trailers all day without any trouble at all.
I watched him in awe and asked him if he could do it with three trailers and he simply said...(add southern accent) "That's impossible."
2004 SE King Cab 4X4 Deepwater
Big Tow
Fog
ARE LSII Tonneau
265 70 R18 Bridgestone Dueler Revos
I shot my rear temps with an IR Thermometer also. First time, stock oil, and just 2 bikes in the bed, after 90 miles I stopped in Mojave, 170 degs, I later changed to Redline synthetic oil, and did the same run withose same 2 bikes AND my off-road pop-up tent trailer(2400 lbs) temp was now about 200 degs.
I still think these temps are a little high for what I was towing, but felt a whole lot better knowing that I had a quality synthetic oil in the diff.
PRG Performance Kit w/SAW's
Born 9/2004
PML also makes larger capacity finned tranny covers too I think. Maybe we should look into one of them too for those that tow heavy loads. Hope we get a report from the Titan owner that they are test fitting the new diff cover on. Should be test fitted next week. 25+ orders now.
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
I got one of them IR thermometers too
they are sweet
Radio SHack Makes a really good one. I remember someone took it apart and it was a the same as a rebadged one that cost over 2x as much like $150, I got mine on sale for $40 The only difference was the $130 one had an LED that turns on when You push the button.
I think it's the first thing radio shack has ever made that was good
I asked the Nissan parts guy about a finned dif cover like the 05s, he said he heard Nissan is going to replace the steel 04s with the finned model. Check with nissan in a few weeks.
Give BLOOD play HOCKEY-04 Titan SE CC Off-Road-05 Honda Odyssey EX-L Res
-89 Honda PC800-99 Suzuki 500 Quadrunner
