Old 04-30-2005, 11:06 PM   #1 (permalink)
Send a message via AIM to toadvb20
thump under drivers side
i have a 2005 xe 4x4. i have been getting a thump under the driver's side whe i would let off the gas or when i would be slowly moving and let off the brakes. my dealer ship said they found a loose crossmember. well it has been 2 days later. the problem is still there. but now when i go over a bump or anything i feel it and hear it. does anyone have this same problem? any ideas of what i should check?
toadvb20 is offline   Reply With Quote
Old 04-30-2005, 11:21 PM   #2 (permalink)
tnbowhunter's Avatar
I don't know if this is your problem or not, it sounds like it could be the same thing..............good luck.
Drive train clunk
"It is not through knowledge, but through experience of the world that we are brought into relation with it."
__Albert Schweitzer
2001 Polaris Sportsman 500.
Old 04-30-2005, 11:36 PM   #3 (permalink)
my problem sounds the same. but i hear it and feel it now everytime i go over a bump or a dip in the road. i saw a couple of people with the 05's found tranny bolts and transfer case bolts loose. i will try them. and then try shock mounts and stuff. the cool part is i work part time for advanced auto so i can get those spring helpers pretty cheap.
Old 05-01-2005, 08:45 PM   #4 (permalink)
found loose bolts. for tranfercase
i read that a couple people found loose mounting bolts fot the tranny and stuff. well i looked under my truck today and found them. they were the two moutning bolts for the tranfer case to the bushing that bolts to a crossmember. the one was about 2 full turns loose. the other was all the way out and jammed between the crossmember and the tranfer case. so i said this is great. i am not touching them i am going to the dealer in the morning. after all i told them to check them. they said they did and they just found a loose crossmember. owell time to break a piece off in the morning.
Old 05-01-2005, 08:59 PM   #5 (permalink)
Banned
jhromy's Avatar
i wonder why that is happening to a couple of members now....i have an 04 maybe i should check mine
jhromy is offline   Reply With Quote
Old 05-02-2005, 09:09 AM   #6 (permalink)
stripped trans bolts.
just got back from the dealer. they said the bolts were stripped out. they had to tre-tap the holes ans replaced the bolts. so i hope they stay tight. i took pics but couldn't get them to insert to this. i am not good at sum computer stuff.
Old 05-02-2005, 12:55 PM   #7 (permalink)
pics of loose bolts to look for
2 trans mounting bolts
Old 05-02-2005, 02:08 PM   #8 (permalink)
Banned
jhromy's Avatar
glad to hear they fixed it
Old 05-02-2005, 07:32 PM   #9 (permalink)
Gearman1987's Avatar
. . . . . .has anyone seen Squids Squirrel lately?
Gearman1987 is offline   Reply With Quote
Old 05-02-2005, 08:19 PM   #10 (permalink)
Banned
jhromy's Avatar
i saw it on the side of the road
Old 05-02-2005, 11:14 PM   #11 (permalink)
Justintoxicated's Avatar
damn now I have to go check mine. I got a clunk that I can feel all the time when taking off or slowing down, and it's not the leaf springs, it does not matter how slow I accelerate or slow down, sometimes it even does it from a crawl to a stop.
Old 05-03-2005, 10:17 PM   #12 (permalink)
did u find them loose? i wish i knew what the torque was on them so i can keep checking them.
Old 05-03-2005, 10:51 PM   #13 (permalink)
Supporting Vendor (Gold)
The torque specs per bolt grade is in the General Informaiton section of the Service Manual...
Front Stage Amp: Mmats SQ2175
Front Stage Amp: Arc Audio 2500XXK
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
a select few."
