Folks,
I'm looking for an extension hose to connect the Schrader valve on the spare tire, while it is hoisted up under the bed, to another location so I can remotely check and fill the spare tire as needed.
Does anyone know who makes such a hose and where I might purchase one?
TIA
Ralph Featherstone
'05 Titan SE KC 4X2
I have never heard of one, but what a good idea. I will bet one could be easily made though. Perhaps after I get my kids car up and running again I'll make an attempt to adapt an old pump fitting to do this.
__________________ 2004 Titan CC 4X2 LE Canteen
You could try any AIT branch, they are Schrader distributors, and have accumulator accessories, as well as hose, fittings. I'd use Parker 801-4 or -6, it's push-lock hose and you could adapt it to the stem fitting and run the hose anywhere you want.
2004 Nissan Titan SE 4X4 Crew Cab
with a bunch of stuff on it.
Folks, I ended up getting a hose manfactured at a local hydraulic hose vender.
I mounted the Schrader Valve on the support bracket that holds the socket for the trailer electrical harness. Easy place to get to and yet out of the way also.
The first photo shows the valve mounted near the trailer harness socket.
The second and third photos show the gray hose wire-tied to the hitch. I used a five foot hose and this is longer than needed, but the extra hose is coiled on top of the spare and acts as a strain-relief on the spare tire Schrader valve.
Now that the hose is installed I am much more likely to keep the spare properly filled at the correct pressure.
Ralph Featherstone
'05 Titan SE KC 4X2
That's cool rdfeatherstone! Thanks for sharing this with us and going through the trouble of taking some digital pics.
I wonder if it could be rigged to send air in the opposite direction using a short hose to air up a flat tire on one of the other wheels after you have put Fix a Flat in it.
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
Why not just change the tire??????
Won't that stuff make the tire way out of balance????? and have to be removed??
Why not just change and use the spare?????
Peace-Tom Bass Ale
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with Big Tow, no more E-loc, Blizzard Graphite/TitaniumInterior, Popular Package, Bench Seat, Bilstein front/rear shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Hellwig Anti-Sway Bar, TrueTrac, Mag-Hytek Honeypot, HK Rear Axle Vent Mod.
ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Ultra L B, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-3rd set, Nitrogen in tires, Frozen Rotors/Hawk Pads, NISSAN I-POD adapter, Bosch Icon blades, Optima Red Top battery.
Amsoil: SEVERE GEAR 75-140W Synthetic In Rear and 75-90 in Front Differential, ATF Synthetic in Transfer Case,
Signature Series 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter.
Bayou Titan,
Sorry, if you keep the spare at regular pressure and then attempt to fill-up a flat tire, you just end up with two tires that are at half pressure at best.
I did read one thread on the Webb where some guy would fill his NEW spare to 120 PSI and use it as an air tank. VERY VERY VERY unwise in my opinion. It might work, but if it exploded, the damage could be FATAL. I can just see it now, running down the highway and the damn tire explodes and punctures my gas tank or shears a brake line. No thanks, nor for me.
Ralph Featherstone
'05 Titan SE KC 4X2
I just bought a new set of tires for my our 2001 Pathfinder, the tire dealer is now filling all their tires with 98% Nitrogen, which has been used by NASCAR, NASA, and commercial airlines for awhile now. I guess the Nitrogen doesn't expand as much when the tires get hot, and tends not tho migrate as much as compressed air. The manager, who I've known for awhile bought a Titan after seeing mine last year, He had the tire sensor problem when traveling at high speed for exteded distances - after filling his tires with Nitrogen he hasn't had the problem. My Titan would do the same thing - after an hour or so at 80mph the tire sensor light would always come on.
