So a couple of weeks ago my truck starting going haywire. Took it in to have a diagnostic ran on it and the codes that came back were U1001 and P5001. What is the best fix for this? :nerd:
The u code is no communication between modules in the can system. Most often I've seen them as past codes caused by low battery voltage. 5001 I've never seen that one. I'll check on assist for you tomorrow. Is the 5001 a nissan code or generic code?
I would say loose connection at one point. If everything still works the way it should then tou should be fine. I would clear it and see if it returns.
Related Threads
Nissan Titan Forum
3.9M posts
142.8K members
Since 2003
