Old 06-05-2005, 09:35 PM   #1 (permalink)
hkusp45's Avatar
Arrow Taking my buddies boat to the river!!
Ok, people. This is the deal. I have the CC with the big tow. And next weekend Im going to pull my buddies boat to thr river. The boat is a 25 or 26 foot bow rider waterjet. My guess is that its in the 3500 to 4000 pound range. We are going from the riverside ca. to havasu about 500 mi. round trip. ok now for the questions........
1. Tow mode?
2. Mostly flat. 4th or 5th in the flats?
3. Rearend seasoning. My Titan will go over 12k on this trip. Do I still have to season the rearend? (no more then 50mph for 500 miles with intermitant brakes to let it cool)
I did do a few searchs but all were pretty vage.
What do you think?
hkusp45 is offline   Reply With Quote
Old 06-05-2005, 09:58 PM   #2 (permalink)
Banned
COTitan's Avatar
I would tell him to take his own truck to save the wear and tear and mileage on yours. I tow pretty often and have found overdrive works well on flat streachs and you get better mpg with light loads as long as the engine is not strugling.
COTitan is offline   Reply With Quote
Old 06-05-2005, 10:03 PM   #3 (permalink)
Small world i am in the same boat as you i am going to be towing my friends 23' daycruzier to and from havasu all summer long. The crazier part is we are from riverside also. The only thing is it is going to be very hard to do 50 it seems to take forever at 80. But i will do 50 do keep my truck from geting damaged. Just have to bring the dvd player though.
mobspade is offline   Reply With Quote
Old 06-05-2005, 10:07 PM   #4 (permalink)
By the way silver 05 cc se with le charcoal leather. Volant and 40 sieries cat back I want to do the 8" cst and some black face 20" rims with 35" Open county m/ts.
Old 06-05-2005, 10:38 PM   #5 (permalink)
1. Tow mode?
What do you think?
I have made same run from palmdale in drive no tow 4th or 5th @ 65-70 no problems titan has just broke 5,000 miles. It will do fine in drive. Have a great time.
my big red is offline   Reply With Quote
Old 06-05-2005, 11:38 PM   #6 (permalink)
If you havent already made the switch i would get some 75w140 for the rear and change it before the trip and tow 70mph without worrying to much.
abmobil is offline   Reply With Quote
Old 06-06-2005, 01:18 AM   #7 (permalink)
hkusp45's Avatar
Thanks for the replys.. I already changed the diff with lucas racing oil. I will make this trip with it in there but when I get back..... It will get replaced. We have a big trip this summer and Ill want all fresh stuff for that......
Old 06-06-2005, 06:44 AM   #8 (permalink)
Clint's Avatar
Yes, you still need to break in the rear end.
I second what COTitan posted and let you friend pull his own toys. My opinion is from the standpoint of when your truck shows its miles later on you'll wish it still had more miles left in it.
Clint
You have two choices in life:
Old 06-06-2005, 06:53 AM   #9 (permalink)
SIMBOSS's Avatar
Send a message via AIM to SIMBOSS
synthetic.
____________________________
Ted
04 LE,CC, 4X4 OR/BT Brawn Red
B.O.D. 04/04/
05 SE 4X4 OR BT Pathfinder Black (girlfriends)
95 Wellcraft Nova Spider 454 Magnum (350 hp)
73 mph (GPS) It really likes the gas too!
89 SE V6 hardbody w/320,000 miles used to pull
my boat.......(needed a bigger truck).
Options in order:
2 degree timing advance thanks to Titanblue,
Fram AirHog, Nissan Hood Protector, Truxedo, Nissan XM receiver (mounted under steering wheel area as per Forum recommendations....worked like a charm)
with non-Nissan much smaller Xm antenna (mounted through Third brake light hole...piece of cake), and last....so far, PRG leveling kit (love it....no problem install after I realized that I really should listen to PRGreg about disconnecting the anti sway bar)
SIMBOSS is offline   Reply With Quote
Old 06-06-2005, 06:54 AM   #10 (permalink)
SIMBOSS's Avatar
Sorry I meant to reply to this message when I said "Synthetic"
Ted
B.O.D. 04/04/
Options in order:
Old 06-06-2005, 08:34 AM   #11 (permalink)
FLA-Titan's Avatar
1. Tow Mode on.
2. Keep it in 4th.
3. Wouldn't worry about the rearend. Your load is not heavy.
Made by NISSAN, Built by Americans on May 4, 2004!
Mods:
Detroit Locker Tru-Trac
FLA-Titan is offline   Reply With Quote
Old 06-06-2005, 12:09 PM   #12 (permalink)
I believe all 75w140s are synthetic, they do offer 85w140 none synthetic but i would definently do synthetic which you already did so you should be ok.
Old 06-06-2005, 02:33 PM   #13 (permalink)
ptgarcia's Avatar
1. Tow mode?
What do you think?
With only a 4000-lb load I would just hook it up and go. If you haven't checked your differential oil yet I would do that before you go. Other than that, have a safe trip!
Pauly
Old 06-07-2005, 09:32 AM   #14 (permalink)
What do you think?
I think a 25 or 26 foot bowrider is going to weigh more like 6000-7000 pounds with fuel and the trailer.
You might want to check with your friend and get the actual specifications.
Nissan Titan SE Crew Cab 4X4
Copper
gf2020 is offline   Reply With Quote
Old 06-09-2005, 04:38 PM   #15 (permalink)
MikeDeuce's Avatar
Does the trailer have surge brakes? And if not, did you make any provisions for an electric brake controller?
WHITE '05 4x4 CC BIG TOW
MikeDeuce is offline   Reply With Quote
