The harness plug is behind the headliner. To remove the visor itself, the pivot point has a small door with 2 torx screws. The clip side has a torx screw too, but can't remember if it has a door too. To unplug the harness, at least the front of the headliner needs to come off. This would recquire removing all sunvisors, overhead console, A-pillar trim, and grab bars to remove the A-pillar trim. You will most likely need to remove the passenger overhead grab handle too. The headliner is stiff, so you don't want to bend it or it will crack and forever be ruined. So the farther back you go removing things the better.
It would be a lot of work to just get an inch or so in visibily of the sky.
