Old 06-20-2005, 11:23 AM   #1 (permalink)
Prodigy Controller Question....HELP
I just installed the Prodigy on that cross bar under the dash. That seems the consensus as being the best location. I used the factory harness and was able to get the wiring down in 10 minutes.
My real question is about the controller itself. I know I can go to the Tekonsha website and I've done that in regards to reading the users manual but I want to make sure my controller is acting the same.
It says theres a power button on top of the controller (blue button) but when I push that I switch between being able to set the 'boost' settings and seeing two red dots (with no trailer hooked up). When the keys are out of the truck, will the LEDS on the controller ever completely go out?
If not, this device certainly wouldn't have the power to impede the battery would it? This is why on my last SUV, I installed a rocker switch under my dash so I could switch the +12V.
Please help........
Jason
scubastud is offline   Reply With Quote
Old 06-20-2005, 11:56 AM   #2 (permalink)
The LEDs go out 15 minutes after the last time the brake is pressed.
Tom
05 Titan SE CC 4X4 | Deep Water | Big Tow
Pop Pkg | Utilitrack w/ extender & divider
Born on 2/05 Mine 4/05
A.R.E. LS II added 6/05 | Step Rails added 4/06
TitanTom is offline   Reply With Quote
Old 06-20-2005, 05:14 PM   #3 (permalink)
Vector's Avatar
Tom has it covered
They will turn off after 15 minutes.
2004 Titan 4X4 LE Crew Cab
K&N Gen 2 FIPK
2 degree timing advance
Nismo Pedals
Sirius Satellite Radio
Lund Hood Deflector
PRG Mini Lift
Axle Vent Mod
Bed Light Mod
Vector is offline   Reply With Quote
Old 06-20-2005, 05:26 PM   #4 (permalink)
Thanks so much......I guess mine is working like it should. I'm the idiot that installed a rocker switch when I didn't need to. Oh well........live and learn.
THanks again
