Old 06-24-2005, 07:33 PM   #1 (permalink)
What weight gear lube to put in 04 rear
They guys I want to change the differential fluid in the rear.I pull a 5000 lbs camper, and after hearing all the problems with the rears want to go to synthetic mobil 1. The question is what weight to put in. The 04 spec is 75-90 I think but on the 05 they are using 75-140. The rears are the identical except for the diff cover. Any feed back would be greatly appreciated
Thanks Bobbyo
Bobbyo is offline   Reply With Quote
Old 06-24-2005, 07:52 PM   #2 (permalink)
There is a TSB changing the specs on the '04 to 75-140. Some people have bought the '05 finned cover and put it on the '04. Some people have bought the extra-capacity finned cover from PML.
http://www.infinitihelp.com/Ownershi.../NTB05-008.htm
http://www.yourcovers.com/dc_10756.shtml
Old 06-24-2005, 08:44 PM   #3 (permalink)
rjspitz's Avatar
If you can find it, get the 75-140 Mobil 1. I couldn't find it locally, so I used Nissan's syn lube.
Old 06-25-2005, 05:55 AM   #4 (permalink)
TOK
TOK's Avatar
Been running 75/140 Mobil1 in my 04 since around 600 miles. Still have the steel cover on there.
04 XE 4x4
1000 Pounds Of Crap In The Back Levelling Kit
TOK is offline   Reply With Quote
Old 06-25-2005, 09:25 AM   #5 (permalink)
Thanks for the feed back guys!!
Bobbyo
Old 06-25-2005, 09:40 AM   #6 (permalink)
I put Valvoline Syn. 75w-140 in mine. Got it Advanced Auto Parts Store.
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
Herbpov is offline   Reply With Quote
Old 06-26-2005, 06:34 PM   #7 (permalink)
I'm about ready to change mine out, how many qts. does it require?
Thanks
Professor is offline   Reply With Quote
Old 06-26-2005, 07:45 PM   #8 (permalink)
TallTexan's Avatar
[quote=Professor]I'm about ready to change mine out, how many qts. does it require?
Thanks[/QU
About 2.25 quarts
Robert Louis Stevenson
Old 06-26-2005, 07:51 PM   #9 (permalink)
supertitan's Avatar
Gear Oil
I Use 75-140 It Really Helps With Gas Miles.
Has Your Diff Cover Turn Rust Color From Heat Baking The Diff Cover.
A Sign Of Low Diff Oil 2qt
supertitan is offline   Reply With Quote
Old 06-26-2005, 09:09 PM   #10 (permalink)
BigRedTitan's Avatar
My cover got baked and rusted just a couple of weeks ago. The case was full, as I topped it off as soon as I got my Titan. It had the 75W90 in it.
I took it in for an oil change and pointed out the cover to the Service Advisor. He had the tech look at it, who in turn ordered me a new rear diff. Two days later, they called me and said the new one was in and I went and got it put on.
According to my SA, if your diff cover has "baked and rusted", it should be replaced because it has already gotten plenty hot. Mine showed no signs of pending failure, but there was metal floating around in the fluid. This was more than enough to get a new rear diff.
...and all I wanted was the cool new finned cover.
Bryan
In memory of Chris- CaliforniaTitan
2004 Nissan Titan SE Kingcab
280 rwhp/ 333 max torque
Born on 03/31/2004--Came Home on 04/15/2004
Red Brawn--Graphite/Titanium
Big Tow, Utili-Trac Package, Rockford Fosgate w/ Power Captains Chairs, Rockford Fosgate Punch P550.2 Amp, 2-Rockford Fosgate Punch P110S4 10" Subs,
AutoExtreme Throttle Body Spacer, Flo-Pro Dual Exhaust, Polished Aluminum Billet Grille, ChromeTailgate Accent, 18"X8.5" MB Offroad Gunner 6's,
265/70/18 Bridgestone Dueler A/T REVO's, Garmin nuvi 255W GPS, PRG Mini-Lift W/ 2½" Front Lift/ 1" Rear Blocks, LED's Front, Eagle Eyes LED Tails,
2 Degree Timing Advance , Clifford Matrix 50.5X Security/ Remote Start
BigRedTitan is offline   Reply With Quote
