Old 06-29-2005, 05:06 PM   #1 (permalink)
Problems removing the oil filter.
It appears that the oil filter is not a screw off/on
I cant figure out how to get it off and I do not want to screw something up
I knew something was up when the filter wrench was too large
Anyone know how to remove the old oil filter and install the new one?
The new filter I bought is a 7317
tbcar is offline   Reply With Quote
Old 06-29-2005, 05:09 PM   #2 (permalink)
rjspitz's Avatar
It is on very tight by the factory. I had to punch the side with a large screwdriver and turn it to get enough torque. Just keep trying, and don't put it on that tight when you install the new one.
Good luck.
Old 06-29-2005, 05:12 PM   #3 (permalink)
The filter screws off/on. I would go to an auotparts store and buy the correct size of socket type oil filter wrench.
Old 06-29-2005, 05:18 PM   #4 (permalink)
I have a huge pipe wrench I will just nut up on it I guess. I might do the screwdriver. I have to leave in like 20 min and I have a truck with no oil lol
Old 06-29-2005, 06:27 PM   #5 (permalink)
Vector's Avatar
Oil Filter
For some odd reason Nissan has an 800lb gorilla putting oil filters on in the engine plant. I had to punch through the filter with an awl, I was then able to remove it without any problem. Its a pain in the @ss the first time.
2004 Titan 4X4 LE Crew Cab
K&N Gen 2 FIPK
2 degree timing advance
Nismo Pedals
Sirius Satellite Radio
Lund Hood Deflector
PRG Mini Lift
Axle Vent Mod
Bed Light Mod
Vector is offline   Reply With Quote
Old 06-29-2005, 06:48 PM   #6 (permalink)
Mike H.'s Avatar
Go pick up a strap wrench. Works great in the tight space.
Mod links (clickable):
Old 06-29-2005, 07:22 PM   #7 (permalink)
TOK
TOK's Avatar
You guys are making me feel like a hero. I didn't have a filter wrench that was small enough, so I spun mine off by hand. Perhaps it was the adrenaline rush when I realized the wrench wasn't going to work and I had already drained the oil.
04 XE 4x4
1000 Pounds Of Crap In The Back Levelling Kit
TOK is offline   Reply With Quote
Old 06-29-2005, 07:25 PM   #8 (permalink)
rjspitz's Avatar
Do you have a brother in Mississippi?
Old 06-29-2005, 07:26 PM   #9 (permalink)
phillipyang's Avatar
Send a message via AIM to phillipyang
i used the special tool that had claws for oil filters. I also had the sleeve as a backup. Came off easy
Nissan Titan LE 4x2 CC
Purchased: Feb 2004
Miles to date: 74,000 (Since Feb, 15 2004)
Mods: Banks Cat Back Exhaust System, K&N with arbox mod, Front Air Dam, Custom bed cover, AC/DC interior conversion, PSP/Ipod Dock
http://www.phillipyang.com
phillipyang is offline   Reply With Quote
Old 06-29-2005, 07:58 PM   #10 (permalink)
pciley's Avatar
The screwdriver hammering and twisting of the new "handle" worked the first time for me too. Just a bit messy.
Common sense: MAke sure you pierce almost @ the end of the filter so you don't damage the threads that protrude from the underside of the block
KC XE Smoke
Old 06-30-2005, 09:21 AM   #11 (permalink)
GETSOMZ28's Avatar
Ditto, I use the same tool. Works great.
Scott
Old 06-30-2005, 11:24 AM   #12 (permalink)
I had the same problem. Had no filter wrench so I wraped the filter with sandpaper and gave it a try off it came.
Bobbyo
Bobbyo is offline   Reply With Quote
Old 06-30-2005, 03:02 PM   #13 (permalink)
It was a load the first time I did it. Mad me mad as @#$$. I was changing it over a pit and had a good view and couldn't get it off. Went to Advance and bought a socket type wrench. Put a universal on my ratchet and an 8" extension and it came right off.
cmclovis is offline   Reply With Quote
Old 06-30-2005, 03:38 PM   #14 (permalink)
Filter question
I was just at AutoZone picking up some supplies to use changing oil. The salesman looked up the Fram/STP numbers and got out the filters it said the truck uses. The filters he had were very small, to small for even the "A" socket that we found to fit the PT Cruiser. I opened the hood and looked down at the filter and it just looked larger to me so I decided to wait on purchasing the socket. Does anyone know what filter socket size Titan filters take?
Mike is offline   Reply With Quote
Old 06-30-2005, 03:47 PM   #15 (permalink)
pagerdaddy's Avatar
My Collection
I have several tools for oil filters. The one that has the jaws and uses a ratchet or breaker bar probably works the best for stubborn filters, but its shortcoming is it is only for removal.
http://www.titantalk.com/forums/atta...achmentid=6042
Steve
pagerdaddy is offline   Reply With Quote
