Old 07-05-2005, 03:52 PM   #1 (permalink)
tonyv79's Avatar
Exclamation Tire Valve Cap Disaster!
The other day I took my Titan to the Nissan dealership(where I bought it) to get the 15,000 mile inspection. One of the technicians told me that he couldn't take off my valve caps and that they had seized. Two weeks after I bought my Titan, someone stole my valve caps so I put some stainless steel ones on. Little did I know that the tire pressure monitoring valve stems and sensors(all one piece) were aluminum. Apparently aluminum and steel don't work well together. The oxidation caused the caps to seize to the valve stems. When I tried to take off the cap, the stem broke letting all the air out of the tire. I ended up putting on the spare and having an independent tire place put on rubber stems for now. I just thought I would warn an others to beware of what you put on your tire valves. I'm gonna try to get Nissan to cover the installation of new tire sensors seeing that no where in the manual do they say anything about valve stems or caps. Otherwise I have to fork over a ton of money to have them replaced. Unbelievable!
2004 Titan SE 4X4, Big Tow Package, Utili Trak, Bed Extender, Bed Divider
tonyv79 is offline   Reply With Quote
Old 07-05-2005, 04:24 PM   #2 (permalink)
TXTitan05's Avatar
Wow, I never thought of that. Thanks for the information and sorry it happened to you.
2005 LE CC 4X2
Smoke
Tow Package
ARE LSII Bed Cap
Born: 10/25/04
Adopted: 11/06/04
2004 Corvette Coupe
TXTitan05 is offline   Reply With Quote
Old 07-05-2005, 06:58 PM   #3 (permalink)
Clint's Avatar
Next time use anti-seize compound to prevent it. Dissimilar metals create corrosion. If you have a steel front door on your home and put a genuine brass kickplate on it, the door will corrode and the brass will tarnish too. Same thing with the steel bolts into an aluminum alternator etc.
Clint
You have two choices in life:
Old 07-05-2005, 07:12 PM   #4 (permalink)
goathead's Avatar
my dad had this happen when he bought some aftermarket caps for his cobra. luckily he checks his pressures all the time and caught it before it got too bad. sorry to hear about your misfortune.
steve
Old 07-05-2005, 07:46 PM   #5 (permalink)
phillipyang's Avatar
Send a message via AIM to phillipyang
How much are they asking for the caps? I lost mine 5 months ago. I have some cheapo autozone ones.
Nissan Titan LE 4x2 CC
Purchased: Feb 2004
Miles to date: 74,000 (Since Feb, 15 2004)
Mods: Banks Cat Back Exhaust System, K&N with arbox mod, Front Air Dam, Custom bed cover, AC/DC interior conversion, PSP/Ipod Dock
http://www.phillipyang.com
phillipyang is offline   Reply With Quote
Old 07-05-2005, 11:09 PM   #6 (permalink)
tonyv79's Avatar
I didn't ask them about the caps, but I know the sensors aren't cheap.
Old 07-08-2005, 06:44 AM   #7 (permalink)
I noticed one of mine missing the other day, I checked the others and found two that were loose. You might check them now and then if they come loose like that veary often.
KT
2005 XE CC 4x4 Smoke
ktee is offline   Reply With Quote
Old 08-24-2005, 10:20 AM   #8 (permalink)
superdelish's Avatar
Angry
The SAME EXACT thing happened to me! I got one off, but the other 3 were seized. The minute I tried to take the next one off, snapped right off. So now, I have to figure out what the hell to do with the other two. This sucks b/c I replaced them with aftermarket caps (since 2 of the original caps fell off).
Anybody have any ideas on freeing the other two. Those damn sensors are expensive not to mention mounting and balancing. These $2 valve caps could end up costing me $300+.
superdelish is offline   Reply With Quote
Old 08-24-2005, 10:47 AM   #9 (permalink)
Doghouse's Avatar
add me to the list.
I did not snap mine, but I quickly replaced them with plastic ones. Heck you can always break plastic.
K-mart has cheap chrome colored plastic ones.
Doghouse is offline   Reply With Quote
Old 08-24-2005, 10:49 AM   #10 (permalink)
I'm just not sure how to go about getting the last two off without breaking them.
Old 11-02-2005, 08:36 AM   #11 (permalink)
Dealer replaced valve caps
Just wanted to let you all know that my dealer in Indianapolis took care of the valve stems. He said that this is a common problem and to put plastic caps on them from now on.
Rock on!
P.S. For those of you in Indy, I dealt with Todd Ryan (Service rep). He was extremely good and much better than the other service rep I had dealt with in the past.
Old 11-02-2005, 09:01 AM   #12 (permalink)
majorKAP's Avatar
Valve Caps
Squirt a little from one of the various penetrating lubricants (i.e. Break-Free) onto the offending area and allow a little time for it to do it's work.
Afterwards, hold the valve stem in place with an appropriate sized wrench to prevent it from turning as you twist the valve cap off.
Might work, might not. I'll accept no responsibility for failure but if successful accolades are in order.
KAP
majorKAP is offline   Reply With Quote
Old 11-02-2005, 11:27 AM   #13 (permalink)
Luckyontheducky's Avatar
If its REALLY bad, try slitting it with a Dremel tool and un-peeling it
Luckyontheducky is offline   Reply With Quote
Old 11-02-2005, 05:08 PM   #14 (permalink)
DryHeat's Avatar
Send a message via AIM to DryHeat
I was thinking the same thing.
................View My Other "Whips"!
DryHeat is offline   Reply With Quote
Old 11-02-2005, 05:41 PM   #15 (permalink)
docopharm's Avatar
wow, thanks for the heads-up. I never thought about it. I'm gonna have to check mine in the morning, I had new ones put on with the new wheels. Haven't had any problems yet, but it's been a few weeks since I checked.
Click for my Site
Retrax, Bushwackers, American Racing Prism,
305/55/20 TerraGrapplers, Interior LEDs,
Painted Side Steps, Hitch Flag, Westin Bull,
PIAA 40's, PRG lift, AFE Stage II, B&B Exhaust,
Front Tint, blah, blah, blah
And no, my screen name does NOT mean Do Cop Harm, it's Doc o Pharm
Vir sapit qui pauca loquitur
docopharm is offline   Reply With Quote
