Old 07-13-2005, 08:21 PM   #1 (permalink)
Electric wax buffer or hand waxing?
Which method do you recommend? If you use an electric one, which brand buffer or what style pads do you use?
Is there any danger or messing up a paint job?
I've been one to use good ole elbow grease but I was curious what the consensus was.....I want a good looking vehicle but I don't want to damage the paint.
Thanks
scubastud is offline   Reply With Quote
Old 07-13-2005, 08:41 PM   #2 (permalink)
raskm's Avatar
porter cable is $99 at lowes...very nice buffer and will not harm paint. You can get all the info at autopia website.
2004 NISSAN TITAN SE CC*4X4*OR/BT*OEM BUG DEFLECTOR*IN-CHANNEL VENTSHADE VENT VISORS (absolute junk!!)*SMOKERS PACKAGE*CATCH ALL FLOOR MATS*NISSAN SEAT COVERS*
raskm is offline   Reply With Quote
Old 07-13-2005, 08:58 PM   #3 (permalink)
This link will answer all of your questions concerning the PC and machine polishing.
http://articles.autopia.org/index.ph...2&id=38&c=root
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
Old 07-13-2005, 09:01 PM   #4 (permalink)
rjspitz's Avatar
I second the porter cable. Just make sure to get a random orbit/dual action polisher with foam pads. I don't recommend you attempt using a professional circular buffer or polisher. These things are very hard to control and can burn the paint. It's very hard to ruin the paint with the random orbit type.
This is a great kit if you are just starting out
And here's another
Old 07-14-2005, 01:28 AM   #5 (permalink)
Titank's Avatar
Post Buffering and polisher
FYI.
Just want to make sure everyone is talking about the same thing.... polisher and buffer are generally referring to different items when talking about body work.
Polishing is for compounding material away from the paint. High RPM.
Buffing is for appliing chemical and remove say chemical off paint. Low RPM.
Buffing with a 'buffer' usually should not damage clear coat and or material that is being worked on. Polishing with a 'polisher' usually does damage to the clear coat (based on compound used) or say material that is being worked on.
I think the originally post was asking about the use of a orbital buffer for waxing and not a true polisher that some have listed. Even when using a wax compound... a true polisher will still cause 'paint burn'.
~Titank
Titank is offline   Reply With Quote
Old 07-14-2005, 06:57 AM   #6 (permalink)
QShip's Avatar
I use the Cyclo.
2004 SE KC 4x4 Titan
B & B Exhaust
Volant CAI
Stillen S/C
Stillen Headers
TruTrak
IPT VB
IPT TC
Uprev ECU
QShip is offline   Reply With Quote
Old 07-14-2005, 12:32 PM   #7 (permalink)
mtbendo's Avatar
I use an electric Craftman buffer, 11 Dia. I don't know if they are available any more. I've had the same one for 20 years now. Still works great. Less swirl marks than hand applications.
04 Galaxy Black Crewcab LE/Big Tow/Off Road/Nav/DVD
Hood Protector/Gibson SS Extreme Duals/Leer XQ Shell/AEM Brute Force
KC Backup Lights/Stainless Steel Grille/Chrome Tailgate Trim/PRG Mini Lift
mtbendo is offline   Reply With Quote
Old 07-14-2005, 12:38 PM   #8 (permalink)
If you're talking about the PC7424, it's really a good price. I 've been watching this and the lowest I found was from Amazon.com for $119 at a sale price (reg was $129). The last time I was at Lowes, they didnt' carry them.
amati5 is offline   Reply With Quote
Old 07-14-2005, 02:31 PM   #9 (permalink)
GETSOMZ28's Avatar
Porter cable is good for polishes and sealants like Klasse, but for just your average wax job, I prefer to do it by hand.
Scott
Old 07-14-2005, 03:06 PM   #10 (permalink)
Vector's Avatar
God I must be old
I like to do it the old fashioned way. By hand.
2004 Titan 4X4 LE Crew Cab
K&N Gen 2 FIPK
2 degree timing advance
Nismo Pedals
Sirius Satellite Radio
Lund Hood Deflector
PRG Mini Lift
Axle Vent Mod
Bed Light Mod
Vector is offline   Reply With Quote
Old 07-14-2005, 03:13 PM   #11 (permalink)
Clancy's Avatar
Ditto. And I've NEVER had swirl problems that way...
Radiant Silver 2004 SE KC 4X4
Popular w/Bench, Utili-Bed, Little tow, Fog Lights, Chrome step tubes, and 1 3/4" PRG kit
Clancy is offline   Reply With Quote
Old 07-14-2005, 03:49 PM   #12 (permalink)
The PC doesn't cause swirls or scratches, it removes them. The PC is one of the most used tools of the professional detailer due to its effectiveness and the amount of time and effort it saves.
BayouTitan
Popular Package
Utility Bed Package
Born on 12/03
Old 07-14-2005, 04:35 PM   #13 (permalink)
3 ways to prevent swirl marks
3 ways to prevent swirls
Swirl marks are mostly the result of modern day multi-step clear coat type paints. This top "clear" coat can be easily scratched.
To prevent this from happening:
1. use a finishing pad, rather than a cutting or polishing pad, since you have a new vehicle that is in good shape. NEVER even think about using a "wool" pad.
2. IMPORTANT be sure that the pad that you use or wrags for that matter are extremely clean. In reality, the majority of scratches and swirl marks are caused by dirt, rather than the buffer-if you are using the right buffer type
The Porter Cable buffer is very unlikely to cause any swirl marks because it is classified as a RANDOM/ORBITAL. This means that it doesn't move in a circular fashion, but more or less mimicks the nature motion of your hands. The speed can also be adjusted. Stay away from high speed buffers, because they only move in a circular fashion can easily burn the paint if your not experienced.
peace and prosperity!
nyoung is offline   Reply With Quote
Old 07-14-2005, 09:45 PM   #14 (permalink)
whodat808's Avatar
how is the PC on waterspots and oxidation? what pad would you recommend using?
On The Horizon:
Flowmasters
Stillen Brakes
Lowering 2/4
ECLIPSE AVN5453 & BEC104
whodat808 is offline   Reply With Quote
Old 07-14-2005, 10:09 PM   #15 (permalink)
Here is an example of what a PC can do with oxidation.
BayouTitan
Popular Package
Utility Bed Package
Born on 12/03
