Old 07-24-2005, 09:15 PM   #1 (permalink)
Titan XE's Avatar
Engine Detailing Tips
Personally, every few months I spray a little Simple Green under the hood with the motor warm and give it a quick spray down with the water hose on mist. I am careful not to soak the altenator, belts etc. I get an old towel and wipe everything down and keep it looking new under there. Be careful to read the Simple Green instructions. They indicate you need to cut the mixture. Get another empty squirt bottle and cut 1 part Simple Green with 4 or 5 parts of water, it lasts quite a while. If you have real heavy build up under any hood here are some simple tips http://www.se-r.net/car_info/clean/detail_engine.html
Proud Owner 2nd Titan. 05 Smoke XE 4x4 Crew Cab, Off Road Package, K&N Drop In Airfilter, Modified Airbox, Spray In Bedliner, Bed Extender, Durakon Custom Fit Bed Mat, Pinstriped, Bell Steering Wheel Cover, AVS Vent Shades, Front Doors DeBadged. Too be continued...
Titan XE is offline   Reply With Quote
Old 07-25-2005, 12:56 AM   #2 (permalink)
Titank's Avatar
I usually...
I do it to a cold engine personally. Hate to spray chem on a warm engine block... may get chemical burn stain on some type of metal.
I also use some foil wrap and cover things like fuse box, non-water tight housing. Mist the engine bay, Simple-Green everything, hose off. Then I attack it with a Shop-Vac using the blow function and blow any water build up out of the frame work. Then sun-dry.
After all dry, I use some transmission fluid to clean any soft rubber... cause the Simple-Green dries up all the rubber hoses.
2005 SE 4X2
- SE Popular w/ Captain Chair
- Big Tow
- Utility Bed
- Traction
MODs:
- Aries Black Nerf Bars
CarDomain Site
~Titank
Titank is offline   Reply With Quote
