Old 08-17-2005, 10:16 PM   #1 (permalink)
smoothTitan's Avatar
attn: wheel guru's help please!
i think i have decided on these
http://www.enkei.com/truck%20specs/solar.html
20x9 i think our bolt pattern is 6-139.7. there are two options the 10 backspacing and the 20. which do i need to keep the stock appearance? i dont want the wheels 5 in outside my fender.
Galaxy Titan KC LE 4x4
Trenz billet
Painted bushwhackers
15% tint
prg front and rear kit
Old 08-17-2005, 10:36 PM   #2 (permalink)
baseballfanz's Avatar
Look nice.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 08-18-2005, 05:50 AM   #3 (permalink)
rjspitz's Avatar
Yeah, I hate that look too. Makes the truck look like a big rollerskate.
Sorry, don't know what the stock backspacing is.
Old 08-18-2005, 12:16 PM   #4 (permalink)
Sammy Sandbag's Avatar
The 20mm offset should move the inside of the wheel 8mm in towards the truck and the outside edge of the wheel 18mm out away from the truck.
The 10mm offset will move the inside of the wheel 2mm out away from the truck and the outside edge of the wheel 28mm out from the truck.
This is based off of a oem offset of 25mm and width of 8"
-Counsel Yourself
Old 08-18-2005, 06:26 PM   #5 (permalink)
thanks alot sammy. good to have guys like you around to straighten us out.
Trenz billet
15% tint
Old 08-19-2005, 07:52 AM   #6 (permalink)
QWIKWHIP's Avatar
Check out this site http://350zx.com/tire-wheel.html It will give you a comparison between stock and aftermarket based on the info you put in. Like sammy said, the stock set up is 18x8, +25mm offset with 265/70/18 tires.
Old 08-19-2005, 08:06 PM   #7 (permalink)
what are the offset of your enkei's
Trenz billet
15% tint
Old 08-19-2005, 08:10 PM   #8 (permalink)
The RT6 20"x9" only comes in an offset of 12mm.
-Counsel Yourself
Old 08-19-2005, 08:28 PM   #9 (permalink)
92TripleBlack's Avatar
You want the 10mm offset. The 20mm may give you rubbing problems with the brake calipers. When I got my wheels, they delivered the wrong offset the first time and we had to return them due to this problem.
Trucks are for raising, cars for lowering!
Post softly and carry a big stick!
'05 Armada LE 4x4, Red Brawn, Graphite, Tech Pkg, DVD, Bench, Nitto Terra Grapplers 305-55-20, MB Motor Express 20x9 rims, 6000k HID lows, Silverstar 9005 Highs and 893 Fogs
'92 Vette Vert-All Black,6-Spd,Sport Seats,ACC,K&N,Custom CD w/sub,Chrome GS Rims,Mich Pilot Sports(275-40-17F,315-35-17R) GS fender flares,Pwr Effects Exhst,Z06 Brakes,Hawk Pads,lowered,camberbrace,Hurst,Stage 3 Clutch,single mass alum flywheel,'96 glass wind top,HAL Qa1 Shocks
'04 G35 Sedan-All Black, Sport pkg, wing, every opt.
'02 Jetta GLS 1.8T Girlfriend's
'04 Kawi STX-15F JetSki
92TripleBlack is offline   Reply With Quote
Old 08-19-2005, 11:41 PM   #10 (permalink)
thanks alot, that would def pose a problem, i didnt even think about them rubbing the brake caliper.
Trenz billet
15% tint
