Old 09-02-2005, 06:04 PM   #1 (permalink)
gr8titan's Avatar
Carbon Fiber Engine Cover Photos
Update: Photos of CF inlay Volant box last post
The OE engine cover had a hole left by the OE intake pipe after I installed the Volant CAI. I subsequently fiberglassed over this hole but just didn't quite look right to me so I ordered a yard of 5.2 oz Carbon Fiber, 3M spray adhesive and liquid fiberglass + hardener.
STEPS: (1) I sprayed 3M adhesive over the cover and on one side of the CF. (2) I carefully adhered and stretched the CF over the engine cover then tucked inside. Trimmed excess CF (3a) I then "brushed" clear liquid fiberglass over the CF and let it cure appx 30 minutes. After which I sanded it smooth while making sure I did not sand down to the CF. (3b) Brushed a thick 2nd coat of fiberglass and this is the state the pictures are in at this time. I will wait for the FG to really cure then fine sand and spray several coats of "clear" for depth.
It's getting dark and my old digital camera doesn't take good pics with flash. I will update this thread as I finish sanding and clear coating the engine cover.
carbon-fiber-engine-cover-photos-dscf0062.jpg  carbon-fiber-engine-cover-photos-dscf0059.jpg  carbon-fiber-engine-cover-photos-dscf0058.jpg
gr8titan is offline   Reply With Quote
Old 09-02-2005, 06:09 PM   #2 (permalink)
37L1's Avatar
Wow, man, you are something else!
That really looks fine, nice work!
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
Old 09-02-2005, 06:17 PM   #3 (permalink)
tnbowhunter's Avatar
Nice!!!!!
2001 Polaris Sportsman 500.
Old 09-02-2005, 06:35 PM   #4 (permalink)
kartman's Avatar
nice. How did you do the see thru volant cover?
Rebar Wrangler
Old 09-02-2005, 06:45 PM   #5 (permalink)
baseballfanz's Avatar
Awsome looking man.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 09-02-2005, 06:54 PM   #6 (permalink)
gr8titan's Avatar
I used 1/4 inch Plexiglass which is available from HomeDepot and kept the original Volant cover as the template. A grinder was used to shape and smoothen the edges. Use slower speed so as not to "melt" the edges of the plexiglass.
As I sit here idle, I'm thinking I should apply CF to the Volant CAI tube to match the engine cover and Volant box. What do you guys think?
Old 09-02-2005, 07:00 PM   #7 (permalink)
Very nice work!! The CF looks like it contours perfectly and no shabby edges. Please post some better quality pictures when it's all cleared and done! Really impressive! I'm assuming you've worked with CF before?
-Cyrus
Vyrus is offline   Reply With Quote
Old 09-02-2005, 07:35 PM   #8 (permalink)
gr8titan's Avatar
-Cyrus
This is the first time I'm toying with Carbon Fiber. However, CF is similar to working with fiberglass cloth which I have done before. Spaying 3M adhesive to the surface where CF is to be applied makes it immovable while applying the clear FG resin.
You bet I will post better quality photos as soon as I'm done sanding it smooth and spraying several layers of clear coat.
Old 09-02-2005, 07:41 PM   #9 (permalink)
RockyMtnTitan's Avatar
Nice job, man....I think most of us would be too scared to tackle something like this...I know I would, at least!
Performance Mods:
Airaid TB Spacer
TB Coolant Shut-Off
Active Tuning Grounding Kit
Int/Ext Mods:
SE Pwr Mirror Upgrade
Factory Step Rails
17" OR Wheels
SE Sunvisors Upgrade
20% Window Tint
Old 09-02-2005, 07:55 PM   #10 (permalink)
Q's Titan's Avatar
Very nice! Now when you gonna start taking orders? lol
Q's Titan is offline   Reply With Quote
Old 09-02-2005, 08:17 PM   #11 (permalink)
Titan Fever's Avatar
Send a message via Yahoo to Titan Fever
Cautions For Working With Carbon Fiber
Warning to all who chose to manufacture with carbon fiber!
Carbon fiber is a complex composite that begins life as polyacrylonitrile (foreign speak for a polymer) and through extensive heating it becomes almost pure carbon in the graphite form. The worst effect of this material comes to the end user who sands this product unprotected (no respirator). The graphite fibers too small to see enter the lungs, that is if you can actually breath, constitutes an almost choking effect when you try and breath, and embed into the lungs. Each time you cough they work deeper into the lungs. This is the onset of a later pulmonary disorder known as pneumonia which will almost always follow after exposure to the graphite fibers in large quantities. I am knowledgeable of this, as I have worked with fiberglass and carbon fiber extensively in the aerospace industry for many years. We had to sit through endless amounts of safety films and were constantly monitored with air quality samplers that test the air for Parts Per Million of the fibrous material. I do remember one certain fiber that was fascinating to look at and touch and to this day still, intrigues me, but is super dangerous in it's raw form, was called angel dust (AND NO To all the drug innuendos). It was the finest form of ground fiberglass I have ever seen. We used it as a thickening agent in a product called hysol that we used as shim material for parts. It served the same purpose as the plastic fibers found in fibermesh concrete to give it strength, but it's softness and finely ground nature was beyond fiberglass properties I had ever known. Anyway getting back to the Carbon Fiber, <<<<<PLEASE PROTECT YOURSELF>>>>> Go to a local paint store, grab one of those tyvec painter suits and tape the cuffs of the arms with masking tape, and use good gloves, and a respirator that will protect you for more than just dust. It is also a good idea, but most of you probably won't do this, but put a little Vaseline around the edge of the respirator, it will keep any loose fibers from getting around the seal as you make faces while you work, and you know that your guilty of this......
I can't stress enough how dangerous it is to sand this product, and I am glad that gr8titan hasn't sanded the raw material yet!
Not trying to be your BIG BROTHER or anything, just passing along very valuable information.
Titan Fever, once with Gulfstream Aerospace, world leader in Global Business Jets
Titan Fever is offline   Reply With Quote
Old 09-02-2005, 08:50 PM   #12 (permalink)
gr8titan's Avatar
Thank you and I appreciate your concern. Anyway, it would be counter-productive to sand the cured fiberglass resin down to the Carbon Fiber surface. It will destroy the CF surface pattern as the untouched CF pattern is the look I am trying to achieve. Sanding the cured clear fiberglass resin to a super smooth surface is an important step prior to clearcoating and that will provide a "super smooth" mirror like final look.
Old 09-02-2005, 09:43 PM   #13 (permalink)
Kronos1965's Avatar
carbon fiber engine cover
Okay, you sold me.
How much for you to make me one? It looks amazing
Kronos1965 is offline   Reply With Quote
Old 09-02-2005, 11:30 PM   #14 (permalink)
rjspitz's Avatar
Looks damn good. Kinda looks like mine. Only my engine bay was very dirty whien I took my pic.
Different take on intake cover
I've since pulled the cover out and replaced it with an OEM one. I'm making a mold so that I can make a direct replacement, rather than an overlay. It's taking a long time though.
Do you plan on doing any more CF parts? I overlayed my interior with CF.
http://www.titantalk.com/forums/atta...chmentid=13540
Old 09-02-2005, 11:52 PM   #15 (permalink)
Looks really sweet....so does your intake
Shadowofnight2001r is offline   Reply With Quote
