Old 09-12-2005, 08:28 PM   #1 (permalink)
Flight Test's Avatar
LED taillight guinea pig.
I said to myself, "Joe, what the hell. Get a set of LED taillights and see how they do." I researched these lights from several different sites and chose to purchase from www.superbrightleds.com. They have 25 total LEDs, 19 pointing to the rear and 6 mounted radially at 90 deg. from the base to fill the reflector. Make sure you get red LEDs. These are direct replacements for the 3156/3157 tail-tail/stop bulbs. Each bulb cost $7.95 each, $5.00 for shipping, total $36.80. They appear to be as bright as the originals. The only downside is they do need a current-limiting resistor because they flash very fast. My question is if I leave it as is, will the lifespan of the flasher unit be shortened? I've attached a few pics for your viewing entertainment. Let me know what y'all think.
led-taillight-guinea-pig-dsc02565_a.jpg  led-taillight-guinea-pig-dsc02566_a.jpg  led-taillight-guinea-pig-dsc02567_a.jpg
Joe
God Bless the USA!
2005 LE KC 4x2
A15/Steel, W07, N94, L92.
Hellwig Anti-Sway Bar
******* Industries: SS Door Sill Trim, Chrome Tailgate Trim
LED tail/brake lights
OEM Bug Deflector & Step Rails
Armada Front Air Dam
Born 4/2005
Brought home 7/7/2005
2000 Corvette Coupe
Flight Test is offline   Reply With Quote
Old 09-12-2005, 08:56 PM   #2 (permalink)
f00dstamps's Avatar
Send a message via AIM to f00dstamps Send a message via MSN to f00dstamps
in my previous car, i had LED bulbs all around. i was most displeased with the brightness of the taillights during the day. you could hardly see it when you stepped on the brakes. however, at night, they looked great! the only thing that convinced me not to switch them back to incandescent bulbs was that i had a 3rd brake light plus a light for my spoiler that was plenty bright. otherwise, i'd be concerned with someone rear ending me during the day.
how is the brightness during the day? are they very visible in direct sunlight? maybe for a fellow TT member, you could switch one side back to the incandescent and take some pics both in the garage again and some outside in direct light so we could see the difference?
2005 CC Titan 4x4 Blizzard White *** SE Popular Package w/ Captain's *** Utility Bed Package w/ Bed Extender *** Offroad Package *** Big Tow Package *** Valentine 1 (hardwired) *** Clifford Matrix RSX 3.5 Alarm + Remote Start *** Amsoil Synthetic motor & gear oil *** 20% Sun-Guard *** Weathertech front floor liners *** Truxedo Lo Pro *** Husky rear floor liner *** HID 4300k Denso/Koito/Philips *** Vulite LED taillights *** Luminarc yellow foglight bulbs *** Scangauge II *** overhead racks w/ kayak attachment *** DR coilovers *** DR rear 4x4 shocks
WANTING TO SELL: bed extender adapter for tonneau covers (i.e. Truxedo)
f00dstamps is offline   Reply With Quote
Old 09-12-2005, 09:23 PM   #3 (permalink)
So the advantage is supposed to be less current draw & heat, but then you have to add a big fat power resistor to draw more current & generate heat? Don't they have solid state timing circuits to flash LEDs? Or maybe they are too expensive?
Old 09-12-2005, 10:06 PM   #4 (permalink)
:withf00dstamps
Replacement LED's are usually too dim in direct sunlight. I'd do this mod if I wasnt worried about getting rear ended. It'd be great if you'd swap one side back to the OEM bulbs and take some dirct sunlight pic's...
SmokenTitan is offline   Reply With Quote
Old 09-12-2005, 10:21 PM   #5 (permalink)
f00dstamps's Avatar
one more thing... you don't happen to be getting a taillight failure dash light are you? are you using a load resistor on the parking light/brake light bulb too?
i was considering retrofitting the taillights with some high-flux LED's. they have outputs of up to 10-20 times brighter than standard LED's. i'd also add those reflective shrouds that direct the light like in the Infinity G35. i'm just gonna wait for some OEM titan taillights to appear on ebay for real cheap.
other advantages of LED's:
- less current draw
- "instantaneous" on/off. LED's turn on in a matter of milliseconds which is SUPER fast when compared to incandescent which takes hundreds of milliseconds. this could potentially prevent an accident because the hundreds of milliseconds could be equivalent to 10 feet or more depending upon the velocity of the vehicles.
- intensity of light
- never replace a light bulb again. most LED's are rated at over 100,000 hours. do the math and that's equivalent to over 11 years if you have the lights on 24 hours a day, 365 days a year.
- it just looks f-in cool!
Old 09-12-2005, 11:51 PM   #6 (permalink)
chunko's Avatar
Fast tailights don't mean sh*t when the as*hole behind you is talking on the phone and turned around whacking their kids in the back seat while doing makeup and taking notes for a meeting. That's why I bought a titan, should be safe when anything short of Mack truck hits me....
chunko is online now   Reply With Quote
Old 09-12-2005, 11:53 PM   #7 (permalink)
f00dstamps's Avatar
bad experience
did you have a bad and bitter experience with getting rear-ended?
Old 09-13-2005, 05:29 AM   #8 (permalink)
Titans do not have a dash light indicating a bad bulb, they just flash very fast. I will try to take pics later with LEDs vs. stock in sunlight. This may prove which ones I stick with. If the stock bulbs appear brighter, I'll put the bulbs back in and send the LEDs back for a refund. I'm not familiar with the QX.
Joe
God Bless the USA!
2005 LE KC 4x2
Born 4/2005
2000 Corvette Coupe
Old 09-13-2005, 05:29 AM   #9 (permalink)
TOK
TOK's Avatar
The thing I like about the factory LED tail lights is that the whole panel lights up, not just a section shaped like a light bulb. Those are cool, but I was hoping you took the guts of a QX-56 tail light and made it work in your Titan.
04 XE 4x4
1000 Pounds Of Crap In The Back Levelling Kit
TOK is offline   Reply With Quote
Old 09-13-2005, 12:21 PM   #10 (permalink)
chunko's Avatar
No, that was meant to be a joke but tone doesn't really come through on the internet. I didn't mean to sound like an a$$.
Old 09-13-2005, 01:57 PM   #11 (permalink)
f00dstamps's Avatar
it's all good. try using some emoticons.
Old 09-13-2005, 02:51 PM   #12 (permalink)
Justintoxicated's Avatar
Wire up the Current limiting resistor...
Is it an LM13T? If your running close to 12-13V to the LED's it won't be disipating much heat. They way these work is they take the unused voltage & current and disipate it as heat. so if your runing 200ma to the LED (if thats what you set the current limiting resistor to) and the LED's take up say 10V and your titan is 14.4V while running then your disipating (14.4-10) * .2 = about a 1/2 watt as waste. You can definately buy more expensive drivers but the titan has plenty of extra power when it comes to a couple watts. hell the whole cluster and resistor take less power than stock in this case.
LED's Can Most Definately be Brighter than Incans, the whole LEd's just are not bright enough can be thrown out. That is going to depend on the LED and how many are used. Hell 1 Red 3 watt LED is going to be so bright it will blind the people behind you if you want it to. People are always telling me the 2, 1 watt RED LED's on my ATV are wayyyy to bright for taillights. See Avitar.
Old 09-13-2005, 02:57 PM   #13 (permalink)
f00dstamps's Avatar
Is it an LM13T? If your running close to 12-13V to the LED's it won't be disipating much heat. They way these work is they take the unused voltage x current and disipate it as heat. so it your runing 200ma to the LED for say (if thats what you set the current limiting resistor to) and the LED's take up say 10V and your titan is 14.4V while running then your disipating (14.4-10) * .2 = about a 1/2 watt.
LED's Can Most Definately be Brighter than Incans, the whole LEd's just are not bright enough can be thrown out. That is going to depend on the LED and how many are used. Hell 1 Red 3 watt LED is going to be so bright it will blind the people behind you.
we're referring to ambient light affecting the incandescent replacement LED's. i have experience with this and during the day, you can barely see the light through a diffused (94 prelude) lens. at night, they look really bright and cool.
i'm pretty sure the item he purchased already has current limiting resistors. the ones i've purchased in the past all have them built in.
Old 09-13-2005, 03:16 PM   #14 (permalink)
It should not be an issue with a 3 watt red LED. hell 1, 1 watt red LED is likely brighter than that whole cluster.
I have a 3 watt Luxeon LED flashlight that fits in the palm of my had that is brighter than a 5D cell maglite...and thats white, red is 2-3 times brither!
Unfortuantly I don't see ANY drop in replacements using these yet, they are much more expensive than general "super bright" LED's...Believe me, if it was not for a difuser lense you would be blinding the people behind you and causing accidents at night.
Old 09-13-2005, 03:54 PM   #15 (permalink)
f00dstamps's Avatar
luxeon LED's are reserved for the OEM LED assemblies where they take great care in doing thermal, electrical, optical studies before even making a prototype. i'm just saying that my "super bright" LED drop in replacement was worthless in sunlight.
