Old 09-13-2005, 02:59 PM   #1 (permalink)
DaveS's Avatar
Rev-limiter saved me on recent tow - when does it kick in exactly?
Last Thursday, I towed 550 miles home from Lake Powell, Utah to San Diego, CA. This is the 6th time I've done this tow, all in 110 degree heat, with no problems at all - my oil, water, and tranny temp guages have never moved while lugging the 8,400 lb boat.
Climbing the steepest grade along the route (southbound I-15 just south of Primm, NV) I was watching the heavy traffic instead of the tach and was doing about 60 in 2nd gear, when the rev limiter kicked in and nearly gave me a heart attack. It felt like the engine just totally died. The RPM dropped to about 4000, then power was restored. Not a fun experience, but totally my fault.
Does anyone know at what RPM the limiter will kick in and how it works?
DaveS is offline   Reply With Quote
Old 09-13-2005, 03:07 PM   #2 (permalink)
nthomp16's Avatar
I don't have an answer to your question, but I just wanted to say that is one beautiful boat!
nthomp16 is offline   Reply With Quote
Old 09-13-2005, 03:21 PM   #3 (permalink)
DaveS's Avatar
Thanks! I'll take you out for a ride if you pay for gas. It holds 120 gallons at $3.93 at the marina I visited. I can use a whole tank in just 1 day if we are skiing and tubing a lot.
Old 09-13-2005, 05:03 PM   #4 (permalink)
HudsonValleyTitan's Avatar
The rev limiter kicks in just a few hundred RPM below redline on our trucks. Next time, leave the shifter in 4th/or with TOW MODE on. It sounds to me like you had it in another, lower gear and were shifting yourself, otherwise it should have upshifted way before the rev limiter kicked in.
- Joe
Old 09-13-2005, 07:39 PM   #5 (permalink)
DaveS's Avatar
I did have it in Tow Mode, but was shifting myself to hold it in 2nd for an especially long, steep grade. Totally my fault for not watching the tach while keeping the revs so high. I was finding that on this grade, even in Tow Mode, it would kick down to third too soon for me, and I'd loose speed that I'd never be able to get back.
Thanks!
Old 09-13-2005, 08:48 PM   #6 (permalink)
Thanks!
Oh you'll get it back alright! Let the auto tranny do its' thing. It works. You may not get it up to 60 MPH, but it'll get you up to proper speed for the climb. Don't expect to ba able to do 75 MPH climbing a really long, steep uphill. If you had it in 4th and left it there, I bet it would have gone up that hill at the same speed you did while self shifting. If must have been doing ok because you hit the rev limiter.
- Joe
Old 09-14-2005, 08:38 AM   #7 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
THere's no way a titan would even pull that grade in 4th with that boat. may be thrid for most of the grade then into second towards the top. But its pretty cool that you could rev it that high, for that long, and still have no problems.
Old 09-15-2005, 09:03 PM   #8 (permalink)
mopar's Avatar
Send a message via AIM to mopar
When the titan is in 4th it just elimninates the overdrive(doesn't just stay in 4th gear) and shifts through the gears as normal but never going into OD. Tow mode adjust the shiftpoints for towing a load.
Sean
RLTW
05 Galaxy Black SE CC 4x4 w/Big Tow Born on 01/05
Borla Cat Back--------AVS Taillight Blackouts
ARE Z series cap------Wade InChannel Ventvisors
OEM Step Rails PC Black-----Weathertech extreme floor liners
K&N 77series CAI------Tailgate mod
Rubber Bed Mat----Custom Bed rug
PRG 4" Perfomance lift--OR Skidplate PC Black w/holes
KMC Backseats 18x9---Procomp Extreme AT 325 60 18
mopar is offline   Reply With Quote
Old 09-16-2005, 12:15 AM   #9 (permalink)
Austin's Avatar
The rev limiter cuts fuel to each cylinder - just as if you took your foot off the throttle.
Don't worry about hitting the rev limiter. It's there to prevent engine damage.
MY04 SE King Cab 4X4 SOLD!
Old 09-16-2005, 02:15 PM   #10 (permalink)
It'll pull it just fine but you're right......it'll shift between 2nd and 4th accordingly and it'll never hit the rev limiter.
- Joe
Old 09-16-2005, 02:55 PM   #11 (permalink)
SoulFish's Avatar
2nd or 3rd maybe.... I tow a 6,500lb boat You definatly feel it on the grades!
- thx
Steve Piazza
04 Titan, Crew, 4x4 SE, Tow, Offroad pack, Locking Rear, RF Sound, Utility bed pack, Pop pack
Mods: Tint, Westin Bull Bar, HID Bulbs
SoulFish is offline   Reply With Quote
Old 09-16-2005, 07:47 PM   #12 (permalink)
My toyhauler is about 9k loaded and on the steep grades in AZ I also have to hold in 2nd gear or I will lose momentum that I couldn't get back once it shifts to 3rd. I've also found that manually shifting it from a stop to cruising speed seems work better than letting it shift on it's own.
XE KC 4x4 Offroad (traded for 06 DodgeRam 2500 CTD 4x4)
My own Big Tow
Prodigy Brake Controller
Sirius Sat Radio
CB
Born on 3/26/04
04 Xterra,Airaid intake
aztitan4x4 is offline   Reply With Quote
Old 09-17-2005, 12:08 AM   #13 (permalink)
RockyMtnTitan's Avatar
Exactly! You guys ever been to the track when the little ricer compacts are in the burnout pits? All you hear is spit/sputter from the rev limiter constantly cutting fuel.
I've hit my rev limit a couple times while doing WOT filter/intake tests....I'm glad it's there. Now when I get a set of performance cams someday....then the rev limiter may be a problem.
Performance Mods:
Airaid TB Spacer
TB Coolant Shut-Off
Active Tuning Grounding Kit
Int/Ext Mods:
SE Pwr Mirror Upgrade
Factory Step Rails
17" OR Wheels
SE Sunvisors Upgrade
20% Window Tint
