Old 09-21-2005, 09:20 AM   #1 (permalink)
Still thinkin's Avatar
Top Speed Limiter?
I replaced my worn out stock tires with slightly shorter(but wider) tires.
I am positive I remember the truck govorning at exactly 180 kph. Now with the shorter tires it governs at approx 177/178 kph on the speedo. Could our truck possibly have a rev limiter in the particular gear that it reaches these speeds at?
Still thinkin is offline   Reply With Quote
Old 09-21-2005, 01:52 PM   #2 (permalink)
johnnyscarecrow's Avatar
Send a message via AIM to johnnyscarecrow
if you change wheel/tire size, isn't it recommended to re-calibrate speedo?
05 Nissan Titan XE CC
98 Acura Inegra RS
96 Nissan Pathfinder XE *R.I.P 5/27/05*
johnnyscarecrow is offline   Reply With Quote
Old 09-21-2005, 06:47 PM   #3 (permalink)
mopar's Avatar
Send a message via AIM to mopar
How do you do that??
Sean
RLTW
05 Galaxy Black SE CC 4x4 w/Big Tow Born on 01/05
Borla Cat Back--------AVS Taillight Blackouts
ARE Z series cap------Wade InChannel Ventvisors
OEM Step Rails PC Black-----Weathertech extreme floor liners
K&N 77series CAI------Tailgate mod
Rubber Bed Mat----Custom Bed rug
PRG 4" Perfomance lift--OR Skidplate PC Black w/holes
KMC Backseats 18x9---Procomp Extreme AT 325 60 18
mopar is offline   Reply With Quote
Old 09-22-2005, 04:59 AM   #4 (permalink)
search for a local shop...(an article that shows the differences due to tire and wheel size)....
Googgle search might work for local area, or a yellow pages, but for 2 or 3 kph at top speed...it's probably not off by that much everywhere...
http://www.web-cars.com/math/speedometer.html
98 Acura Inegra RS
Old 09-22-2005, 12:13 PM   #5 (permalink)
Resident Titan Guru
How can you register a 2-3kph change in speed by the speedo? That's either 1.2 or 1.9 mph.
2005 Titan- Bright Red- 4WD LE
20Titan05 is offline   Reply With Quote
Old 09-22-2005, 01:47 PM   #6 (permalink)
Titan1080's Avatar
You can use a quality GPS unit to find out changes in speed due to changes in tire size. Just compare before and after numbers.
AKA, Rusty Whore™
2004 Titan XE KC 4x4 DOB 12-15-2003
Compare your truck to mine and then kill yourselves!
Click Here to see a list of things I did to void my warranty
My Picture Gallery
Titan1080 is offline   Reply With Quote
