console shifter
A couple of times I put the truck in park and couldn't turn or remove the key. It turns out that the shifter handle is sticking to the right side of the gate and as soon as I tap it to the left I can hear the solenoid click and the key can be turned and removed. The service manager said to stick the little tube from a can of silicone between the shifter and the plack plastic surrounding it at the base and give it a short blast. I was at the dealer to order a new seat cover and since the truck wasn't in the shop I asked him what "I" could do to fix it. Just a heads up if it happens to anyone else...
Clint
You have two choices in life:
