Well, winter is just around the corner, and I must say that the biggest unfixable problem I've had so far is the freezing door handles. Has there been any fullproof mods that anyone has done to prevent this from occurring. I know that there were many who had this problem last winter, and was just looking to correct the problem before it happens again. Thanks
really, my maxima had the same type of door handles as my titan and i never had a problem. the only difference is the size, titans being bigger of course. we had a terriable winter last year here in the northeast. damm i hope this dont happen this year then
I feel for ya buddy but the moving south idea worked for me.
__________________ IRC VK56 Member "BIG CHIEF WANNARACEUM"
2005 XE, "Land Shark",1/4 MILE: 13.851 AT 98.52 Full Street Trim on Snow Tires Record HolderBuild date 3/05
Performance mods: UpRev, JWT cams, NISMO CAI, NISMO True Duals with Dr Gas Xpipe, NISMO Headers with Swain's White Lightning Coating, Suncoast Ram Air Hood, Tru Trac, Burnout mod
Stereo mods: Pioneer Premier DEH-P880PRS head unit, Audison LRX 4/300 Amp, Boston 6x9 coaxials front & Focal 6.5 coaxial rears with JL tweeters in dash.
the door handles really freeze??? U sure your not just yankin our chains alittle
" You want me? F%*&in come and find me, I'll be waiting with a gun and a pack of sandwiches " Radiohead
"Me I'm standing right down here in Texas, I know that's where I was always meant to be" Pat Green
Trust me, they will freeze up.
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
I've had the problem a couple of times here in Louisiana. When you try to close the door it doesn't latch. When you try to slam it shut, it bounces open.
I think there should be a recall since there is a huge safety issue of driving a truck with the door open.
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
i believe if you spray wd40 on the latch mech periodically they shouldn't freeze--ie keeps away all the moisture.
this is from many sub 30 BELOW in minnesota eh!
It's the cable that operates the latch that freezes up. Can't lube it uless you take the door apart and that doesn't even help some time. I'm willing to bet that I'll be making another visit to the service dept. for the same problem this winter. Made two visits last year.
Can you say 'remote start'? If you parked it with the heat on hot and the blower at about 3/4 would that take care of it? (Don't leave it on recirc, fresh forces inside air out some will escape through the doors...)
__________________ Chris
05 Blizzard LE CC, 4x4, BT, OR, Nav, AB, Sunroof, XM, Ceramic Pads on new rotors & hardware (10.2k+miles,no brake issues to date and very clean wheels), AutoExtreme TBS, TB coolant bypass, Inverted helper springs, Hi-capacity diff cover, Active Tuning ground kit, poly swaybar bushings (front), Axle Vent Mod
This is my first winter with my Titan, and this morning it was 5 degrees when I was getting ready to leave for work. I started my truck via the aftermarket remote starter and let it run for a good ten minutes. Went out to the truck and my handle froze....spent probably ten minutes slamming and re-slamming my door until it finally latched.
I hope this is not what I have to look forward to all winter. I am starting to get the impression that the R&D money was spent engine/tranny...interior was left to the interns.
'05 Titan KC SE 4x4 - Canteen - BOD 3/05 | K&N CAI
I don't have the door latch freezing shut problem and my truck has been sitting outside in snow and -F temps for the last few days. I installed sound deadening (bituminous + foam) in the doors.
We had some rain/sow/sleet mix over the weekend, plus the temps dropped into the low teens-my door opened right up, even with snow and ice all over it.
Yesterday, I decided I needed to wash the pig, since it was getting pretty dirty-outside air temp, 25 degrees, BRR!! On top of that, I was in the stall, and def. not in the sun, but still, the door opened right up?
SOLD**2004 SE CC Radiant Silver 4X4 w/ Pop. Pkg and DVD
**SOLD
SOLD **2005 Titan XE KC w/ Preferred Package BLACK **SOLD
My driver door handle froze shut last night. I came out of the store and tried to open my truck and wasnt' really thinking about it. I pull kinda hard and something snapped inside the door. When this happened before I could just auto roll the window down and open it by reaching inside...but it wont even open that way now. My door is stuck shut. I have to climb through the passenger side. Unacceptable in my opinion on a 35k + vehicle. Goes for service monday.
2005 Smoke CC BT OR
ProComp Stage 2
PRG Leveling
Deaver Full Spring Pack
Total Chaos upper arms
20" Moto Metal 951's
36/13.50/20" Irok Radials
Husky Liners
Lund Stainless Hood Guard
Lund Tri-Fold Tonneau
Rear diff's be ware....I will break you
Because lifes' too short to drive an ugly truck...
