Did you get a neoprene adhesive-backed pad with the kit? You'll need it to place under the airbox to cut some vibration. You can also drill out the mount holes on the box and install the rubber isolators from your oem box. This is what several of us have done with the Volant. I even did this on the Gen3 Volant kit....the more isolation the better.
As far as oiling the filter....reoil about every 3K miles or so. The oil that Volant uses is more MAF-friendly than other oils, but dries out much quicker. After using up the filter charger kit that you got with the kit, I'd recommend using the AFE filter charger kit....it's oil is MAF-friendly, as it does not use a sticky surfacant like K&N. Should allow you to go at least 30K miles between oiling/cleaning.
Performance Mods:
Airaid TB Spacer
TB Coolant Shut-Off
Active Tuning Grounding Kit
Int/Ext Mods:
SE Pwr Mirror Upgrade
Factory Step Rails
17" OR Wheels
SE Sunvisors Upgrade
20% Window Tint
