Old 10-04-2005, 02:52 PM   #1 (permalink)
GO_VOLS!'s Avatar
TSB for AC
Just currious to see how those that took their truck in for the TSB work on the AC fared. What all did the stealer do to the AC system and how are the results?
I've been waiting for the right time to take mine in and get this performed, as the AC barely gets cold. Just wondering if it's worth it.
Straight, White, Republican Male
(How else may I piss you off today?)
Loaded '09 LE 4x2 CC w/ Max Utility Pkg, Navi, sunroof, DDM HID low beams (35W 5000K), I-pod interface, chrome bug shield, Nissan rubber floor mats, and Retrax tonneau cover.
GO_VOLS! is offline   Reply With Quote
Old 10-04-2005, 03:01 PM   #2 (permalink)
Mine was not cooling at idle, that's exactly what the TSB is for. Not that it doesn't blow cold when moving... it always blew ice cold.
Anyways they reprogrammed the ECU and replaced the fan. Still didn't have a fix for the A/C drain problem!! So I advise you do that on your own.
-Cyrus
Vyrus is offline   Reply With Quote
Old 10-05-2005, 10:27 AM   #3 (permalink)
Had mine done....after leaving gregs house I went to vegas...in 118 heat it was blowing nothing but warm air. After the TSB it is better...but it still isnt what I would call really cold. It is a lot better though...well worth the TSB trip.
Shadowofnight2001r is offline   Reply With Quote
Old 10-05-2005, 11:49 AM   #4 (permalink)
llajumpvid's Avatar
My AC would just quit blowing cold air at times when it was hot outside and I was in stop and go traffic. Two days after I had the AC TSB done we evacuated Houston so I had 19 hours of stop and go traffic. In the first 9 hours and 5 miles it never did shut off the compressor but the AC did quit cooling and I would have to let it rest for 30 minutes or so then I could get some cooling for about 15 to 20 minutes (117 degrees is what my mirror temp was reading). Once we were moving again it got ice cold. Several times after we had been moving and were slowed to a crawl again I could here the compressor shut off and then a second later restart, once however it didn't restart until I shut off the AC AND FAN , then turned it right back on and it worked fine. I say get the fix. The fan is definately quiter now and has a deeper sound than the previous screaming noise I had...it's not quiet though just quieter.
The shallow end of the gene pool needs some chlorine!
April 04 Armada
Mods: 20% tint, Blaupunkt ME3 TV/DVD player wired into factory dvd wiring (read how to here) , 7" monitor (see it here), video on Navigation screen (how to here) , reverse camera, hood deflector, weathertech vent visors, sunroof deflector, Cascade sound deadener, Street Scene Grille and a fully functioning car-mada-puter, Download fauxdynoV3.0.xls
llajumpvid is offline   Reply With Quote
