I posted this in Wheels/Tires, etc., and had 158 views, but no informative responses. Thought I'd try again here.
"Thread title says it all. I'm switching over to BFG, AT 315/70/17, KO's. Ideally, I'd like to get five of them and mount the spare up underneath where it is now. I'm wondering if it would fit if deflated. Someone here mentioned that they thought that it would.
I'm interested to hear if any of you have done this. It looks like it would be close and with being deflated, it just might work. I have a VIAIR, 400P compressor, so I'm not worried about airing it up when the time comes.
Any one done this?
Regards,
John"
05 LE CC 4X4 - Red Alert w/every factory option
American Racing Chrome Chambers 17X9 Rims
Offroad/Big Tow
Damello Offroad Custom Rock Sliders
Retrax rolling bed cover
Bed Extender
Rancho 4" lift w/ PRG Traction Bars
Fox Coilovers & Total Chaos Upper A Arms & Deaver Leaf Spring Upgrade Pack
1", Billet block in rear w/Bilstiens
Defender Roof Rack w/6 offroad lights
Mile Marker Winch mount brush guard with Warn 9500 Ti winch
Bushwacker fender flares (black)
just measure between the frame rails where the spare winches up. If it is more than 35 inches you're set! However, if you deflate the tire then when you tighten the "winch" down to hold the tire in place you could draw the metal rim up against the metal frame and that won't stay tight for very long or will cause metal/metal wear.
Galaxy Black 2004 Titan XE CC 4x4 w/ Off-Road Package, Preferred Package.
Mods: PRG Spacers, 17x9" Eagle 187s (+2mm offset) w/ 315 70-17 BFG All-Terrain KO tires, Stillen Diff Cover, Alpine Type-R components in the front, coax. in the rear w/ 50 x 4 Rockford Fosgate Amp, XM, Debadged, and Homemade RCA pre-outs on in-dash changer.
Very good point, Vegas. I never thought about it. Is it OK to let the tire with no air for a long time?
If the frame rails are too narrow, maybe you can just deflate it a bit and sotra wedge it in between them. The rails could compress the sides a bit and and then your spare tire "winch" could touch only rubber. Possibly? Its only another 2" though, so chances are there's that much more room underneth.
2005 Titan SE 4x4
Floor Mats
Splash Guards
Nissan Drop-in Bedliner
Front windows tinted to 35%
In-Channel Vent Visors
Front Husky Liners
STEREO:
Pioneer DEH-P8MP Head Unit
Maybee I'm missing something here. Why would you deflate the spare tire just to fit it under the truck? That would defeat the purpose of having a spare. If you get a flat tire instead of one flat tire you will have two because you will not be able to use the spare until you inflate it again.
__________________ 2004 Galaxy XE CC 4x4(DOB 8/04)
* Power package * Bed extender
* Off road package * Rear elocker
* XE Preferred Package
MODS
* DVD/TV tunner 7" Headrest Monitors
* Stock airbox mod
* SE power mirrors upgrade
* XM Radio "Skyfi2"
* PRG leveling kit
* 2005 Aluminum Diff Cover upgrade
Why not just use the original spare???? It's just for emergencies only. It can't be any worse than one of those "get ya there" doughnut spares.
2001 Polaris Sportsman 500.
I already post this question regarding using original spare on CT. Other members said that it might damage your gear.
LOL, yeah it might...........if ya drove it for several thousand miles going 90mph,
So... for a short distance then it's OK? Anyone please give more confirmation?
Well, a spare is supposed to be used for emergencies, right?
I personally wouldn't be afraid to use it as long as you reduced your speed[50mph] and were only going to drive a short distance. I.E. the nearest service station.
As I said earlier, it couldn't be any worse than one of those doughnut spares that a lot of cars and truck use. You just have to exercise some caution.
I would happy if my spare can handle up to 35 mph.
I was thinking the same thing since the Titan doesn't have a mechanical limit slip diffy. I do wonder how the electronic active limited slip would react on the highway though...
04 Galaxy Black Crewcab LE/Big Tow/Off Road/Nav/DVD
Hood Protector/Gibson SS Extreme Duals/Leer XQ Shell/AEM Brute Force
KC Backup Lights/Stainless Steel Grille/Chrome Tailgate Trim/PRG Mini Lift
It would freak out....for awhile at least. I have the VDC switch, so I'd turn it off.
PRG Performance Kit w/SAW's
Born 9/2004
