Old 10-11-2005, 09:53 PM   #1 (permalink)
Tire pressure sensor location?
Am getting new tires installed and am wondering if I need to tell the install place about my sensors. Are they located on the rims, tires, or in the valve stem? If so, and I replace the tires, does the shop need to do anything special?
I'd hate to have to drive around with that darn light on all the time. It's gone off a few times since I've had the truck and each time, I had low tire pressure in one of the tires, so it seems to work as designed.
Regards,
John
05 LE CC 4X4 - Red Alert w/every factory option
American Racing Chrome Chambers 17X9 Rims
Offroad/Big Tow
Damello Offroad Custom Rock Sliders
Retrax rolling bed cover
Bed Extender
Rancho 4" lift w/ PRG Traction Bars
Fox Coilovers & Total Chaos Upper A Arms & Deaver Leaf Spring Upgrade Pack
1", Billet block in rear w/Bilstiens
Defender Roof Rack w/6 offroad lights
Mile Marker Winch mount brush guard with Warn 9500 Ti winch
Bushwacker fender flares (black)
John Harden is offline   Reply With Quote
Old 10-11-2005, 10:08 PM   #2 (permalink)
Sammy Sandbag's Avatar
The sensors are part of the valve stem. You just need to have them transfered over to the new wheels. I know some people have had trouble with them seating and sealing correctly with aftermarket wheels, but it just depends. BTW, if there are no sensors present, then the audible alarm will not sound and the light generally takes anywhere from 30-75 miles to turn on.
-Counsel Yourself
Old 10-11-2005, 10:11 PM   #3 (permalink)
Wait, sorry I misunderstood you. I thought you were getting new wheels. If you are just getting the tires replaced, then no there shouldn't be any problem. You might just want to give them a heads up, but I wouldn't think that there would be an issue.
-Counsel Yourself
Old 10-11-2005, 10:22 PM   #4 (permalink)
rrumaner's Avatar
Send a message via ICQ to rrumaner Send a message via AIM to rrumaner Send a message via MSN to rrumaner Send a message via Yahoo to rrumaner
There have been people in the past that stated that the kids at the tire store would break the stems because they didn't know they were connected to the sensor. Make sure you get someone who understands the process or be prepared to spend additional (I am not sure how much) money to replace them.
Roy Rumaner
Any questions about the site etc. Lets us know!
rrumaner is offline   Reply With Quote
Old 10-12-2005, 08:48 AM   #5 (permalink)
Supporting Vendor
P's Titan's Avatar
They cost over $100 each, I went through the drama with Pep Boys breaking one. Please make sure they are careful while putting them back in. If not you will have a small leak and will have to fill air up everyday. The valves are sensitive when the tire is put back on to the rim. If I were you I would watch them do it, you can tell if they do it right.
my mods list
USE DISCOUNT CODE FOLGER FOR FREE SHIPPING OFF ANY ORDER OVER $100 www.adamspolishes.com
CrankyWhore™
Blah Blah Blah Whore™
TequilaWhore™
Old 10-12-2005, 09:16 AM   #6 (permalink)
scr38's Avatar
If they don't know about the sensors they can easily break them. They need to remove the core from the stems to fully deflate the tire. Then remove the nut from the stem/sensor and push the stem inside the tire. This must be done before the bead is broken on the tire. After the bead is broken push down on the sidewall so you can reach inside and remove the sensor before the tire is removed from the rim. After the new tire is put on the rim, push down the sidewall to reinstall the sensor.
You may want to print out this and take it with you.
See attachment.
Old 10-12-2005, 02:47 PM   #7 (permalink)
Thanks for the replies. Geez, who knew there was so much involved in changing tires on these. That's fine though, as I like the tire pressure sensors on mine. Each time they've gone off, it's been due to low tire pressure.
Yes, it's just the tires that are being replaced. The stock rims stay on.
They're also going to try and wedge the spare back up under there with a deflated 35" tire on it. I'll let you know if it fits. Right now, it looks like its going to be darn close.
Thanks also for the installation procedure. I printed it out and will give it to them to help ward of 2nd or 3rd visits back to correct problems.
Thanks again.
John
Offroad/Big Tow
Bed Extender
Old 10-12-2005, 02:52 PM   #8 (permalink)
See attachment.
Thanks Scr38!!!!! I am going to print this and keep it in the glove box. They almost broke one of mine when I had the tires changed. I will give this to them next time.
Old 10-12-2005, 07:36 PM   #9 (permalink)
Waterfowler's Avatar
When I had my tires replaced I forgot to mention the sensors to the garage. I tested one tire and the sensor went off when the pressure dropped but was too lazy to test the other three. So here's my question:If they sensors were indeed broken, would the warning light go on?
Waterfowler is offline   Reply With Quote
Old 12-01-2005, 01:41 PM   #10 (permalink)
Re: Tire pressure sensor location?
Thanks for the tps instructions. I got an earful on these things from various venders at the SEMA show. I'd like someone to straighten me out on these issues so I can plead a case for some fixes:
1. TPS are US$80-100 each?
2. You cannot rotate tpms wheels as each is coded to location?
3. The standard 17" steel wheels collect kilos of mud due to their weird design?
4. Chevy Silverado wheels bolt on (correct bc and offset)?
5. tpms are proprietary to whom? tire manufacturer? wheel? platform?
6. Low temperatures create false tpms alarms?
What I want is a 'factory' way to turn the system off whenever it's necessary.
TIA
John
2005 Titan XE KC 2wd
1990 Infiniti Q45 (chip, K&N, Tokiko blues, PowerSlots, PerfFriction, Bridgestones on 8x16 Etoiles)
1983 Porsche 911SC (came from a barnyard, headed for the track)
Clipboard is offline   Reply With Quote
Old 12-01-2005, 01:46 PM   #11 (permalink)
KTMNealio's Avatar
Send a message via AIM to KTMNealio
I just got my tires put on (aftermarket wheels) and they broke 1 sensor off. It was $71 at the stealership (they had me run get it, but they covered the cost). Just make sure you don't have some n00b puttin your new tires on and you should be fine. Express concern up front and you should hopefully get someone who knows what they are doing.
- Nealio
2005 SE - Smoke CC 4x4
My Titan's wheels and tires
KTMNealio is offline   Reply With Quote
