From what I've seen, read, and tried to do myself, the answer is no and no.
The tailgate assist actually uses one of those pneumatic type cylinders that are used to lift the hood. It's installed behind the right rear brake light. Apparently it requires some mounting tabs that are installed on the body, and I believe there is some bracing in that area that isn't present on the '04 models. I believe someone on the forum was going to try to retro-fit it to his truck, but I don't recall hearing much more about it.
As for the rear window, the '04s have a completely different back wall than the '05s and '06s with the rear power window. However there is a company that sells a power rear window that slides to the side.
-Counsel Yourself
2009 Blizzard Pro-4X
