Old 10-13-2005, 12:52 PM   #1 (permalink)
20TITAN04's Avatar
Exclamation Afe & Oil Pressure Gauge
Has anybody that installed the AFE intake notice their oil pressure gauge rising with acceleration ? This was discussed in a thread a while back ,and was found to be normal for the needle to almost be pinned if you stomped on the gas during the first couple of minutes of driving after a cold start. The needle will then settle at the mid point after warm up and not really move much anymore. After installing the AFE stage II kit i notice the oil pressure needle rising to the 3/4 mark at about 3000 rpm and a little higher at about 3200-3600 rpm ,even after extended driving ( 15-20 mins ). Just wondering if anybody else noticed this , and if i should be concerned. Thanks...
2004 TITAN CC LE BIG TOW
DVD...CLIFFORD REMOTE START
OEM CHROME RIMS...Z GRILLE... ARIES SS STEP RAILS...CHROME TAILGATE TRIM
RETRAX ROLL TOP COVER...XENON LOW/HIGH BEAMS
POWER TAILGATE LOCK....TAILGATE ASSIST
PIAA REVERSE FOG LIGHTS...UNDERSEAT STORAGE BIN
SIRIUS SPORTSTER...
7'6" BOSS SNOW PLOW
20TITAN04 is offline   Reply With Quote
Old 10-14-2005, 01:47 PM   #2 (permalink)
20TITAN04's Avatar
Any one notice this????Whistler, lenj33,RockyMtn???
I know at least 14 people purchased the AFE on the group buy...
SIRIUS SPORTSTER...
7'6" BOSS SNOW PLOW
Old 10-14-2005, 01:58 PM   #3 (permalink)
smoothTitan's Avatar
my truck does this without the afe. i dont think you have anything to worry about. just normal oil pressure. i would be worried if i had low oil pressure.
Galaxy Titan KC LE 4x4
Trenz billet
Painted bushwhackers
15% tint
prg front and rear kit
Old 10-15-2005, 07:05 AM   #4 (permalink)
SupraTitan's Avatar
Yea that means your engine has good oil pressure. It should rise as rpm's rise, minimum 10psi per 1000 rpm. Guage can be pegged when cold because the oil is resisting being pumped, hence pressure rises. The titan's oil pressure guage appears to be mechanical as it reacts instantly, toyota's typically use electronic guages which are slow to react. Just avoid pegging the guage as this means oil is possible not getting to where it needs to, also you could possibly blow the seals out with too much pressure.
04 Titan CC,BT,OR,4X4, 5333lbs, 15.42@88.79mph stock
Zoomers catback, 2* timing advance
SupraTitan is offline   Reply With Quote
Old 10-15-2005, 04:47 PM   #5 (permalink)
RockyMtnTitan's Avatar
Yeah, mine has always done this. No noticable difference after installing the AFE....I wouldn't worry about it.
Performance Mods:
Airaid TB Spacer
TB Coolant Shut-Off
Active Tuning Grounding Kit
Int/Ext Mods:
SE Pwr Mirror Upgrade
Factory Step Rails
17" OR Wheels
SE Sunvisors Upgrade
20% Window Tint
Old 10-15-2005, 04:52 PM   #6 (permalink)
baseballfanz's Avatar
Mine does it too before I installed my intake (AEM). Nothing to worry about.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 10-15-2005, 05:43 PM   #7 (permalink)
20TITAN04's Avatar
My truck did it also before i installed the AFE , but i don't remember the needle rising that much after driving around , lets say... 15-20mins .
Maybe im just paraniod???
SIRIUS SPORTSTER...
7'6" BOSS SNOW PLOW
