So I was heading North on I95, cruise on 75mph when all of sudden I hear a loud clunk/clank and suddenly the breaks self engage and I hear a metal scraping sound. I pull off to the side and notice the ABS AND SLIP lights are on. Luckily I was able to pull into the VA welcome center parking lot.
Loud scraping sounds like it's coming from passenger side; dark out so I can't really inspect.
Just had it in for service this morning before my trip north. New struts and shocks, oil change, brake fluid flush, tires. Brake pads and rotors were still good.
Getting towed as I write this to Nissan of Roanoke Rapids. I'm 3hrs from home (MD) or else I'd get it towed home.
Stealer opens at 0900 so any advise/help before I walk in tomorrow would be appreciated.
Been searching and can't find my specific problem so figured I'd ask.
Re: Cruising on I95 -> loud clunk-> brakes self engage-> ABS/SLIP->metal scraping sou
Doesn't matter if it was engaged or not, they just fall apart, and depending on what your doing at the time, take out other things like sensors. Passenger rear wheel hotter is potentially a sign.
So they quoted me over $1600 plus tax and 2 days of shop time due to parts not being in stock.
They said the ebrake went to **** which damaged the hub, axle, shaft and bearing. "Vehicle needs entire drum brake Kit, rear axle shaft, bearing and wheel speed sensor"
I said no thanks.
They removed all the shards of broken parts.
Had to drive it another 3 hours home. Sounds like **** but I made it with no additional hassles.
Parts list is attached. Cheapest a place to order?????
Pops is coming down and we're going to tackle this repair ourselves.
I had that happen to my 2010 Titan @26,000 miles, last year my ebrake blew up so i called Nissan and fought with them to take so responsability and got them to pay for the parts and i had to pay labor which came to $200.00. They had to replace right rear brake caliper,lever toggler.ebrake shoes,spring ,adjusters and sensor assy.So i would call Nissan 1st to try to get help speak to a regional specialist.
