Old 10-16-2005, 10:33 PM   #1 (permalink)
kartman's Avatar
Tire Sensor problem
My low tire light turned on the other day. Checked all the tires, 1 was low at 29. I inflated all of them to 32 and the light remains. Anyone else had this happen?
Rebar Wrangler
Old 10-16-2005, 10:36 PM   #2 (permalink)
DryHeat's Avatar
Send a message via AIM to DryHeat
Fill them to 35, drive around a bit and you should be OK.
................View My Other "Whips"!
DryHeat is offline   Reply With Quote
Old 10-17-2005, 01:38 AM   #3 (permalink)
tnbowhunter's Avatar
I agree, 35psi is the correct tire pressure.
2001 Polaris Sportsman 500.
Old 10-17-2005, 04:25 AM   #4 (permalink)
honeykeeper's Avatar
Send a message via Yahoo to honeykeeper
Thumbs up No problems with false signals!!!
Never had one problem with mine........I tested by lowering one tire to 27 psi....never made it out of the driveway before the indicator came on.
Pumped it back to 36 PSI.......indicator went off before I hit the main roads.
This system works great!!!
Kartman......sounds like a trip to the SM is next.
3-29-05 Born 4/09/05 Adopted SEKC 4 x 4 Off Road with Big Tow, no more E-loc, Blizzard Graphite/TitaniumInterior, Popular Package, Bench Seat,
Bilstein front/rear shocks, Deaver Mini-Pak Springs, Total Chaos Shackles, Hellwig Anti-Sway Bar, TrueTrac.
In-Cabin Microfilters, ARE Z shell..OEM bug/rock deflector, Lund AVS Ventvisors, OEM mud gaurds, Bushwhacker- notched-Fender Flares, OEM rubber & standard floor mats, Stainless Steel Titan Door Sills, Black Vinyl Door Edge Molding on front doors and vertical sides of Tailgate, Spoiler Direct Chrome Tailgate Trim, Utilitrac System, OEM Dual Lower Sliding Trays, OEM under-seat-storganiser, Silver Star Low Beams, White Night Backup Lights, CT Windshield Sun Reflector, Drawtite Activator II trailer-e-brake control, Super-Z-Winter Traction Cables, Dueler AT REVO Tires-2nd set, Nitrogen in tires, Rear Axle Vent Mod, NISSAN I-POD adapter, Bosch Icon blades, Optima Red Top battery.
Amsoil: SEVERE GEAR 75-140W Synthetic In Rear and Front Differential, ATF Synthetic in Transfer Case,
Signature Series 0-30W synthetic engine oil, EAO13 oil filter, EaA104 Nano-fiber engine air filter.
6 x 10' low bed/rails trailer with E-brakes. 108 year old rebuilt 4,000 lb. road roller/packer.
"We have the Capability & Technology to Eliminate 100% of our needs for Persian Gulf Oil" R.F.K.Jr. 7-07:
http://www.youtube.com/watch?v=Heku9oTLysg
honeykeeper is offline   Reply With Quote
Old 10-17-2005, 04:53 AM   #5 (permalink)
It's probably a fault sensor. Mine comes on at highway speeds over 20 minutes even though they are 35psi.
virus is offline   Reply With Quote
