Recently I have noticed a drop off in my gas mileage, has anybody noticed this? I keep track of my gas purchases from my first tank. For the most part these entries are all city miles (except for the 16 / 17 mpg entries.) Recently it seems like I have trouble keeping the mileage above 14. My driving habits havent changed any. I am not complaining per se, just concerned that something is wrong, and looking for some feedback from some other owners.
'05 Titan KC SE 4x4 - Canteen - BOD 3/05 | K&N CAI
That's weird, my Titan did exactly the opposite of yours. I now have 5090 miles and the mpg is getting better (15.7) all of which are intown miles. I have not been out of town yet. I have been taking it easy during the first 5000 miles to break it in. Have you changed the octane of fuel? I use the middle grade (88 octane). I have also changed the oil twice. The next one will be at 6000 miles. All of this is of course my personal opinion which I have observed. Hope this helps.
__________________ 2005 Galaxy Crew Cab SE 4x4 With Big Tow, Rockford Fosgate, Utilitrack System Mods: De-Badged 35% Front Tint Sylvania Silverstars All Around OEM Foglight Kit Active Tuning Ground Kit OEM Rubber Mats Magnaflow True Dual Custom Exhaust with X-Pipe
my gas mileage falls in the same parameters. My city driving gets roughly 12.8 to maybe 14 on a good tank. highway i'm around 15.5. i have always been told your gas mileage should improve slightly over time as the engine breaks in. i wouldn't worry too much. its bound to fluctuate some due to uncontrollable variables, i would think it'll creep back up to mid 13's, low 14's eventually. just a thought
Has it been getting colder in NY? You might want to check your tire pressure. I was getting slightly worst gas mileage these last couple of weeks. I checked my tire pressure and it was down about 5 lbs all around from where I normally keep them. I aired them up and I'm getting better gas mileage now.
'04 SE KC 4X4
Galaxy Black
Big Tow
Popular Package Mods:
Tech Tubes step rails, Truxedo Lo-Profile, K&N CAI, Flowmaster catback exhaust
MB Motoring Express 20"X9", Nitto Terra Grapplers 305/50 - 20
Sylvania Silverstar hi & lows, OEM fog lights, Blacked out OEM Grill
Armada front air dam, 2* timing advance
It has been getting colder, that is a good idea about the tire pressure. I will check it tonight. I just did my first oil change we shall see if that helps with the mileage (switched to M1 EP 5w30.)
I've got a little over 3000 on mine now and still getting around 12.5. It does, however, seem to be running a little stronger than when new. I'm sure that's because of the cooler weather.
I could tell you more if I had stayed at a Holiday Inn Express last night!
__________________ DW
2005 Titan 4x2 LE CC
22x9.5 Eagle Alloys Series 170
305/45R22 Falken Ziex
Stillen Brake Pros Big Brakes
A.R.E. Tonneau
Precision Billet Grills
Banks Monster Exhaust
I know all about the cold and tire pressure. The first 'chilly' morning here, my tire sensor went off! So, I'd say my tires were a little low...DOH!!
As for the gas, it could be the winter mix starting, I think that's what its called.
The other thing cold(er) weather brings, longer warm-up times. I know that alone wouldn't account for gas mileage change you've seen, but add that, plus tire pressure, PLUS cold weather mix, and you might have the answer...
BTW-Mine did the opposite too-it started low, around 10.5 and went up to 15+...
SOLD**2004 SE CC Radiant Silver 4X4 w/ Pop. Pkg and DVD
**SOLD
SOLD **2005 Titan XE KC w/ Preferred Package BLACK **SOLD
May be pretty obvious, but have you checked your air filter?
__________________ 2004 Titan 4x4 Pearl White LE King Cab
Tekonsha Voyager Trailer Brake Controller
OEM Bed Divider
Superior leaf spring helpers
Lund X-terminator bug shield
Graphite/Titanium leather seats
Born-on date 6/10/04
Purchased 6/19/04
Mine seems to fall into that same category (milage wise it look like your chart). One thing that puzzle me is when new and I was getting 14 mpg avg. I had to fill up once every 6 days, now with the lower mpg I fill up every 7 days (same driving habit, same route to work and home, basically same routine). I use to get 300 miles easy on a tank but now about 275 - 280 the most. Don't know if it's related but notice the lower MPG after my first oil changed to synthetic.
I wish I could get your lowest gas milage! Right now im lucky to get 11.5 miles per gal. Of course I tow off and on. But still the last time I got over 12.5 miles to the gal I had to drive like the rest of the old farts down here and I cant have that. I figured it wasnt worth the savings to drive so slow. I would rather lose a mile per gal and have some fun doing it.
Along with the change in wintertime gas formulation, might add into the equation of colder air being more dense thereby taking more power (and more gas) to push our large frontal area at speed. Granted the engine will produce more power with denser air but my feeling is aerodynamic drag subtracts more in efficiency than this increase in power adds.
KC LE 4X4 Built 03/04, Sedona, Big Tow, XM Radio, Remote start, Billet grille, Advance bed cover, Chrome tailgate cover, '05 finned diff. cover, Armada air dam
