Old 10-22-2005, 06:45 PM   #1 (permalink)
Pinging solution
My Titan with over 25k is starting to ping when it drops into 5th and when I accelerate.
Has anyone used a good fuel system cleaner to fix this. I always use Shell or Exxon gasoline.
KenedyTXTitan is offline   Reply With Quote
Old 10-22-2005, 07:15 PM   #2 (permalink)
I allways alternate between premium and reg. gas to keep the ping out. If I use straight reg. gas all the time it will definatly ping.
Old 10-22-2005, 09:26 PM   #3 (permalink)
Old Speed's Avatar
its probably spark knock. just carbon buildup on the valves. go to costco and buy a 4 pack of the chevron techron stuff for 20 bucks, put 2 bottles per 1 tank then i go to chevron when it is close to E and fill up with premium. then repeat with second 2 bottles if need be.
worked good on my 02 Ranger when i did that
05, Smoke titan, SE, king cab,w/ big tow pakage
Old Speed is offline   Reply With Quote
Old 10-22-2005, 09:28 PM   #4 (permalink)
Send a message via ICQ to gtbigup01 Send a message via AIM to gtbigup01
BG44k it's the best fuel system cleaner out there. Most dealers use it, problem is, it's like $27 a bottle.
gtbigup01 is offline   Reply With Quote
Old 10-23-2005, 05:44 PM   #5 (permalink)
My dealer wants about $100 to clean the system...Is this a good price or should I try the BG 44K tank additives.
I forgot to mention I ran $20 (two big bottles) of Techron thru with no redution in the pinging...
Old 10-23-2005, 05:47 PM   #6 (permalink)
I may try again with the Techron. Two shots in a row
Old 10-23-2005, 10:39 PM   #7 (permalink)
Old Speed's Avatar
yeah your just making the gas burning more hot to try and burn off all the carbon on the valves and pistion
Old 10-24-2005, 06:11 AM   #8 (permalink)
mick3643's Avatar
Get out on 181 and blow the soot out of it. All this babying around to conserve gas isn't good for any engine. don't try to keep the beast bottled up!!! :.)
2005 2wd SE Crew Cab
air bags
turbo muffler
Scan guage
Bd tuner beta
mick3643 is offline   Reply With Quote
Old 10-24-2005, 06:15 AM   #9 (permalink)
Considering $27 a bottle, $100 for the dealer to clean the system is not bad for the peice of mind.
Old 10-24-2005, 08:11 AM   #10 (permalink)
SickWhip's Avatar
I was always told to not use most the different additives out there to avoid gumming up my engine.
I want my baby back, baby back, baby back....
Old 10-24-2005, 08:58 AM   #11 (permalink)
My dealer wants about $100 to clean the system.....
all they'll do is run an additive through the system...........my dad always has said that a good run down the interstate from time to time, and not just from one exit to the next, is good for the engine.
titanQ is offline   Reply With Quote
Old 10-24-2005, 09:04 AM   #12 (permalink)
Supporting Vendor
P's Titan's Avatar
I think your right... I believe in the manual it say's not to use anything like that in the titan. Then again who know's, it also say's not to modify the truck in anyway.
my mods list
USE DISCOUNT CODE FOLGER FOR FREE SHIPPING OFF ANY ORDER OVER $100 www.adamspolishes.com
CrankyWhore™
Blah Blah Blah Whore™
TequilaWhore™
Old 10-24-2005, 09:25 AM   #13 (permalink)
Try running some GM top engine cleaner. A lot of guys swear by that stuff. Since you have only 25K miles, why are you being charged for this?
Tell the dealer that you're still under warranty and the truck shouldn't ping like that. Pinging means detonation and that's bad for the engine. Get them to fix it for you. You might have an O2 sensor that's going out or something. Better to have the dealer do it under warranty than you footing the bill when you reach 36K miles.
'05 Titan XE
K11 Smoke
18" LE wheels-Leer 700 tonneau cover-Ram air hood scoop-SRT-10 rear spoiler-PRG leveling kit-OEM bodyside moldings-OEM foglights-Dunder upper/lower grill-Painted brake calipers-Stainless exhaust tip-Hellwig rear swaybar-Armada front airdam-Rear storage bin-All weather mats-Microfilters-Alarm with power door locks-Hood decals-Fram airhog-Tint.
Coming soon: Painted rear bumper-Bullydog-OEM bed extender....
miketan is offline   Reply With Quote
Old 10-24-2005, 11:20 AM   #14 (permalink)
I hadn't talked to my dealer about this yet, just saw the price advertised on the service board....
I think Shell is a top tier gas, and since I use my Shell card I could prove this to the dealer and have them clean my system at no charge.
Old 10-24-2005, 01:20 PM   #15 (permalink)
sgbofav's Avatar
A much better alternative to the $100 dealer method is Fuel Power or FP60 www.lubecontrol.com . This product is well respected on The Additives, Fuel,Oil, Cleaners Forum
2004 Deepwater Nissan Titan, Crew Cab(10/24/04)
AMSOIL SVG 75w-140 gear lube
AMSOIL SAE 10w-30 oil
"No arsenal, or no weapon in the arsenals of the world, is so formidable as the will and moral courage of free men and women.
- Ronald Reagan
sgbofav is offline   Reply With Quote
