Originally Posted by bestatchess
For Big Tow with stock gearing:
4th @ 65 mph = 2300 RPM (from Boat & Trailer 2004 towing vehicle article)
5th @ 65 mph = 2300 x 0.834 = 1918
5th at 60 mph = 1918 x 60/65 = 1770
5th at 70 mph = 1918 x 70/65 = 2066
Thanks Best. I've already done all the math - just wanted to make sure my initial RPM assumption was correct.
I think I'll end up going with 4.10's. If I did 4.56's I'd be just over 2650rpm at 75mph, which would make it less of a highway rig. 4.10's drop that number down to around 2400rpm, which is probably going to make quite a difference in fuel economy ('cause, ya know, that's why I bought the Titan... to get good mileage...
That sounds delightful! Where are you getting the gears for the front differential?
Same place - Dynatrac. There is another company up here in my neck of the woods working on it (Randy's Ring & Pinion), but Dynatrac will likely get done with it first. They're saying they're pretty certain they can get a high pinion Dana 44 to fit the front case with only slight modifications. I'm jumpin' on it.
It'll be nice to have ARB's front & rear.
Using the bigger tires gives a ratio of 32.7/37 = .883 is almost the same as the 5th gear overdrive of .834 so it is like you are already in 5th gear with stock tires when you are actually in 4th gear. (Maybe that is why you are asking about RPMS in 5th gear?)
Obviously not why I'm asking - buy you're correct - in 4th gear, my truck acts as if it's in 5th gear with OEM sized tires. That makes for a really pissed truck when I actually let it shift into 5th gear - it just doesn't like it. I usually keep it in 4th, so it'll be nice to have 5 forward gears again.
What would be really nice is a 4 to 1 transfer case!
Atlast makes one -
www.advanceadapters.com - but I don't think they're quite ready to offer it to Titans yet. They were a couple months away last time I talked to 'em.
