Old 10-28-2005, 05:52 PM   #1 (permalink)
What makes a "Big Tow"
What makes a Big tow package able to tow more than a regular configuration. Trans/oil coolers?
Old 10-28-2005, 05:56 PM   #2 (permalink)
Sammy Sandbag's Avatar
Lower final drive ratio. I believe both non-BT and BT Titans have a trans cooler, but the BT model has a trans temp gauge.
-Counsel Yourself
Old 10-28-2005, 05:59 PM   #3 (permalink)
So thats it? If that was it I can only assume that a non-BT could really tow more than the 7500 they say. True?
Old 10-28-2005, 06:00 PM   #4 (permalink)
37L1's Avatar
TOW PACKAGE
x x x
- Class IV receiver hitch
- Lower final gear ratio (3.36:1); similar to a four-speed automatic 4.10:1
- Additional seven-pin wiring harness plug
- Trailer brake controller pre-wiring on IP
- Transmission temperature gauge
- Extendable tow mirrors (N/A on XE)
- Heavy-duty battery (710 CCA)
- Increased tow capacity
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
Old 10-28-2005, 06:04 PM   #5 (permalink)
Originally Posted by 37L1
TOW PACKAGE
x x x
Right, but none of those things increase the towing capacity except for the gears.
Sure it can tow more than 7500lbs, but what a truck can tow, what it can tow safely, and what it's rated for may all be completely different ammounts.
-Counsel Yourself
Old 10-28-2005, 06:05 PM   #6 (permalink)
TOW PACKAGE
x x x
The increased tow capacity intails all the above not somthing additional though correct?
The reason I ask this is I have a aftermarket class IV hitch and a 7 prong wiring harness. Ive never towed more than 8000 lbs but I often wonder if I could with no probs!
Old 10-28-2005, 06:07 PM   #7 (permalink)
37L1's Avatar
The info I posted is from NissanUSA. I know nothing else about the BT.
Born 11/18/03
-Gambit
Old 10-28-2005, 07:30 PM   #8 (permalink)
Smoke05's Avatar
You probably could tow over 8,000lbs with no big tow, but at what cost to the tranny and engine? The ratios are different for a reason and without the whole truck works harder. I'm sure the Big Tow could pull more than 9,500lbs, but the manufacturer placed that as a limit for a reason.
Smoke05 is offline   Reply With Quote
Old 10-28-2005, 07:56 PM   #9 (permalink)
Titans with offroad have the same gear ratio as big tow. As far as tow capacity goes an ex with offroad should theoretically tow about 10000lbs based on the trucks weight and max combined weight rating. However Nissan artifically lowered the tow rating on ex to sell more se and le versions.
PA Titan is offline   Reply With Quote
Old 10-28-2005, 08:06 PM   #10 (permalink)
I think I will keep the extra towing capabilities as a sort of reserve. Thanks guys for your input here!
Old 10-29-2005, 08:29 AM   #11 (permalink)
IMO it's risky to tow more than the weight for which the truck is rated. The rating is based upon more than final drive ratio, or tires, or hitch, or harness, or suspension, or temp gage, or oil cooler, or mirrors, etc. Tow capacity is based upon the integrated added capacity offered by the totality of the equipped truck... plus maybe a little marketing hype.
A very real risk of towing beyond capacity are the consequences of an accident or injury. If a lawyer gets wind of the fact that you've exceeded the tow rating of your truck it's going to give him/her a real lever to pry extra $$$ out of you or your insurance company. It may also give your insurance company a way to weasel out of paying anything for the damage or injury. Even if the police determine that you were not at fault overtowing can undo that determination.
YMMV.
JefeCinco is offline   Reply With Quote
Old 10-29-2005, 08:35 AM   #12 (permalink)
Good point! I dont plan on towing over. I just wanted to know if it could handle it and if I happen to be towing a 7000 lb boat and the gear, tanks, water, gas, etc. cause it to go over would it be ok. And is the frame or something like that stronger on the big tow trucks?
Old 10-29-2005, 08:37 AM   #13 (permalink)
No, everything is identical except for those things mentioned in this thread.
-Counsel Yourself
Old 10-29-2005, 08:46 AM   #14 (permalink)
You have the benefit of living in a "flat" state which helps to take a lot of the strain off when towing. I realize that you will be on an incline coming out of the boat launch, but that is only a short distance, at slow speed, and you can use a low gear.
How far will your usual tow be?
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
Old 10-29-2005, 08:57 AM   #15 (permalink)
15 to 20 miles.
