Curious to what axle ratings are.
Since I don't have my truck anymore, I can't look but am curious.
With a Crew Cab 4X4 Off Road packaged SE or XE WITHOUT BIG TOW, what is the Front Axle Rating and the Rear Axle Rating. The GVWR should be 6499 lbs as that was my 2004 CC OR 4X4's GVWR. My truck weight was ~5150 lbs according to my ~1350 lbs payload sticker in the door jam.
Could you also state the axle ratings with the same optioned Titan above but with the BIG TOW PACKAGE.
That way a comparison can be done against Titans with and without the Big Tow package.
My New Nissan Pathfinder weighs loaded between 4750 lbs and 4800 lbs and it's Front Axle Rating is 2775 lbs and it's Rear Axle Rating is 3500 lbs. It does come standard with Tow Package. It's GVWR is 6000 lbs.
According to Car and Driver, it's Weight ratio is 51% front and 49% rear. The Titan's ratio is 54% front and 46% rear.
Thanks and have a good one.
