LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 10-11-2005, 09:00 PM   #1 (permalink)
superhawk's Avatar
Flashing Air bag sign
I installed a new indash DVD today and it fit perfect, but now my airbad light is flashing.
Any ideas?
DR's, Bilsteins
33x12.50x17 Procomp Muds over Centerlines
superhawk is offline   Reply With Quote
Old 10-11-2005, 09:02 PM   #2 (permalink)
Sammy Sandbag's Avatar
Easy fix:
1)turn ignition switch from off to on
2)within 1 second after the aribag light starts to flash---immeditely turn the ignition off
3)after ignition is off, wait for more than 5 seconds
4)then repeat steps 1 through 3---do all steps 3 times
5)turn the ignition on, and the airbag sensor should go off and not flash anymore
Might take a couple tries to get the timing down, but it does work.
-Counsel Yourself
Old 10-11-2005, 11:04 PM   #3 (permalink)
phillipyang's Avatar
Send a message via AIM to phillipyang
I had this problem before i found out about the above solution, if you can't do it, the dealership will gladly do it for you.
Nissan Titan LE 4x2 CC
Purchased: Feb 2004
Miles to date: 74,000 (Since Feb, 15 2004)
Mods: Banks Cat Back Exhaust System, K&N with arbox mod, Front Air Dam, Custom bed cover, AC/DC interior conversion, PSP/Ipod Dock
http://www.phillipyang.com
phillipyang is offline   Reply With Quote
Old 10-12-2005, 08:58 AM   #4 (permalink)
Vegas04's Avatar
threads like this are what make this forum so awesome.
... oh yeah, and the heads threads about nitrous
... and those pictures of the new stillen supercharger.
... oh and Austin's e-locker solution.
God bless Titantalk.com!!
Galaxy Black 2004 Titan XE CC 4x4 w/ Off-Road Package, Preferred Package.
Mods: PRG Spacers, 17x9" Eagle 187s (+2mm offset) w/ 315 70-17 BFG All-Terrain KO tires, Stillen Diff Cover, Alpine Type-R components in the front, coax. in the rear w/ 50 x 4 Rockford Fosgate Amp, XM, Debadged, and Homemade RCA pre-outs on in-dash changer.
Vegas04 is offline   Reply With Quote
Old 10-12-2005, 12:22 PM   #5 (permalink)
It happened to me when the dealer replaced the head unitfor the crappy reception. Apparently when you turn the ignition on (like to check if your head unit works before you put the dash back together) while the "passenger airbag off" light is unplugged it will cause the airbag MIL to blink on the dash.
blkbubba is offline   Reply With Quote
Old 10-12-2005, 01:44 PM   #6 (permalink)
superhawk's Avatar
Problem solved,, THANK YOU VERY MUCH!
DR's, Bilsteins
Old 11-07-2005, 04:12 PM   #7 (permalink)
That worked......I tried it before and I could not get it to work, but it worked like a charm this time. All you have to do is try it a few times to get the timing down. It may be frustrating, but it does work.
Chromematrix is offline   Reply With Quote
