Go Back   Nissan Titan Forums > Titan Discussion > Titan General Discussion
User Name
Password
B-LSD Warning light coming on at dead stop WTF - being discussed at Nissan Titan Forums in the Titan General Discussion section.
Old 11-09-2005, 05:39 PM   #1
brassballs1979
Well, my B-LSD light comes on now every now and then when I am driving my 04 Titan. I am pretty sure it is just a bad sensor beciase I will de driving down the road and the E brake light will come on along with the B-LSD light, but the E brake one will go off after a few min. The B-LSD one wont though. It is going into the shop on Friday for warranty work. My question is what, if any, damage can be done by driving with this light on?
I have attached some pics....
Click image for larger version
ID:	18039  Click image for larger version
ID:	18040  Click image for larger version
brassballs1979 is offline   Reply With Quote
Old 11-09-2005, 05:45 PM   #2
scr38
scr38's Avatar
Check the brake fluid level. If it is low it will cause this.
Old 11-09-2005, 06:32 PM   #3
Old Speed
Old Speed's Avatar
i was wondering what makes that light turn on.
05, Smoke titan, SE, king cab,w/ big tow pakage
Old Speed is offline   Reply With Quote
Old 11-09-2005, 07:06 PM   #4
TYTAIN
TYTAIN's Avatar
Sounds like a trip to the dealer. I'd let them replace the trim around the radio controls on the steering wheel while I was there, looks like the paints coming off.
2004 Titan LE CC 4X4 Offroad Blizzard
Chevron 10W30, Amsoil 75W140 Severe Gear
PRG Performance kit and BFG 315/70/17 All Terrain TA KO's"
PRG Rear Shackles (waiting on installation)
2004 Nissan Altima 2.5SL
2004 Polaris Sportsman 500 Camo W/Winch
TYTAIN is offline   Reply With Quote
Old 11-10-2005, 10:32 AM   #5
brassballs1979
I checkd my brake fluid and it is in the noraml range, ablut halfway between min and max
Old 11-12-2005, 08:53 AM   #6
culbrze
culbrze's Avatar
Send a message via AIM to culbrze Send a message via Yahoo to culbrze
I had this happen a couple times too, and both times I added fluid even though it was in the acceptable level range. It cured the problem.
2004 Nissan Titan XE 4X4 King Cab
Born On 11/17/03 Sedona
1985 T-Bird Turbo Coupe - "Yeah !! you just got Smoked By a 4 Cylinder"
1986 Camaro SC - Shorty Headers into 3" Duals Dynomax, 3:73 posi
2004 Toyota Highlander 4WD
culbrze is offline   Reply With Quote
Old 11-12-2005, 09:26 AM   #7
Armada
Armada's Avatar
As your brake pads wear, the pistons in the calipers have to extend further out to push the pads against the rotors. That takes more fluid.
The marks on your brake fluid reservoir are only estimates. You can safely add up to about halfway between the mid mark and maximum.
My bet is that when you do that, the lights will go out. They did on mine.
'04 Armada SE Offroad 4x4
Galaxy Black
K&N Drop In Air Filter w/ airbox mod
Carbotech Bobcat front brake pads at 28K miles (no brake judder, just time to change pads)
Armada is offline   Reply With Quote
Old 11-12-2005, 09:22 PM   #8
bfiii12
Send a message via Yahoo to bfiii12
I had this happen a few times. The first time I took it to the dealer and they just added some break fluid which cured the problem. The second time my break judder was starting to get pretty bad. And when I got the new break parts it cured it. Hasn't happened since.
'04 Titan Smoke
4x4 Off Road
MODS:
Vent Visors
Delta Tool chest
PRG Leveling Kit
Lund Bug Deflector
bfiii12 is offline   Reply With Quote
User Name
Password
Search this Thread:
Advanced Search
vB code is On
SEO by vBSEO 2.2.0
