Another noise
I am getting a wierd noise the last couple of weeks. It only happens when the truck has been parked for awhile. It only happens when pulling out of the driveway or a parking spot. It only happens at very slow speeds and only for about 50 feet or so. It sounds like it is coming from the back half of the truck. It is similar to when you wet your finger and run it around the rim of a wine glass, but the sound has a much deeper bass sound to it. It almost sounds like the brakes are rubbing the rotors or something is to tight in the rear end or the axel is too tight. I don't know.
It stops when I get going and does not do it again even if I park and restart the truck. Touching the brake peddal does not stop this while it's happening.
