Old 11-14-2005, 06:43 PM   #1 (permalink)
Finally got some results at dealership service dept!
Well my Titan finally started showing signs of the brake issue. And I had this strange clicking noise coming from under the driver side dash. I took the day off of work and headed to the dealership.
This was the second time I took it down for the noise issue, the first time they blamed it on my wheel lock in the glove box! Anyway, as far as the brakes they replaced the front pads and rotors and the note for the rear brakes says, "Machined rear brake rotors and replaced rear pads per TSB", what does Machined mean? I don't want to sound stupid, I just don't understand what they mean by that. There is night and day difference in the brakes, I guess I didn't realize how bad it had gotten.
As far as the noise they said it was a "front cowl" causing the issue and they inserted foam from the sqeak and rattle kit. This solved this issue as well.
Good job Landers Nissan in Southaven, MS!!
2005 Red Alert Titan SE CC
OEM Running Boards and Bed Extender
Sirius, Retrax, Bug Shield, Splash Guards, Vent Visors
paulallen is offline   Reply With Quote
Old 11-14-2005, 06:50 PM   #2 (permalink)
Re: Finally got some results at dealership service dept!
"Machined" means that they took a thin cut off the rear brake rotors on a brake lathe to true their surfaces.
Old 11-14-2005, 06:51 PM   #3 (permalink)
baseballfanz's Avatar
Exclamation Re: Finally got some results at dealership service dept!
Machined the rotors means they resurface it to make it smooth again. Its a normal process with any vehicles when you get your brake service.
Titan/Armada Part Numbers
305.5 WHP, 370.4 ft/lbs tq
Old 11-14-2005, 07:03 PM   #4 (permalink)
Well it works wonderfully!! I am very pleased.
Service Dept. Vent TitanRN Titan Problems & Dealer Service 4 08-03-2005 02:38 PM
Nightmare with service dept yesterday paulallen Titan General Discussion 4 07-17-2005 09:10 PM
Here's one to Nissan dealer service dept htn123 Titan Problems & Dealer Service 2 03-15-2005 04:47 PM
2 Reasons to look for another service dept The_Man Titan Problems & Dealer Service 1 03-09-2005 11:55 AM
Choosing the Right Service Dept? buster Titan Problems & Dealer Service 5 12-07-2004 01:30 AM
