Old 11-18-2005, 11:29 AM   #1 (permalink)
YosemiteSteve's Avatar
Pillar Spot Lights
Here is the installation of my Unity Pillar spotlights. This is not for the faint of heart as you have to drill a 1/2 in hole completely through the pillar. The pay off is a wonderful spotlight that is adjustable. I opted for this because the light is adjustable 360 degress vs. those that are just fixed on a bracket.
REMEBER TO MEASURE 2 or 3 times before drilling and use the right template with the kit. You'll need to by the light kit and the install kit both available from the Unity website here: http://www.unityusa.com/
No going back from this mod by the way...
pillar-spot-lights-111605-170a.jpg  pillar-spot-lights-111605-168a.jpg  pillar-spot-lights-111605-172a.jpg  pillar-spot-lights-111605-181a.jpg  pillar-spot-lights-111605-187a.jpg
2004 - SE - 4x4 Off Road Package - White
Exterior:“Wincher” front bumper with Ramsey 9500 / Synthetic Rope Winch*PIAA Off Road/Fog Lights in Bumper*ProComp 35” 325/65/18 Extreme AT Tire*ProComp 8089 Series Extreme Alloy Wheels*ProComp 6” Lift Kit w/ES Series Shocks*Unity Pillar Spotlights R&L*Dual Optima Battery System w/Painless Wiring Solenoid Kit*On Board Air Compressor with 10ga tank*Challenger Series Tool Box*Banks Exhaust*Unity Night Eyes Under Carriage Lights*Overhead Rack w/Yakima Mega Warrior Basket*PIAA Pencil Beams on (front rack)*PIAA Flood Lights (rear rack)*Stillen Big Brake Kit*LED Lighting
Interior:
Pioneer AV1NC Navi/XM/DVD/Back-Up Camera*Yaesu UHF/VHF Radio*Cobra CB* Uniden 100 Scanner*2-Streamlight Stinger Flashlight Mounts*Aircraft Map Lights*Prestige Theft System w/Autostart & Satellite Tracking Service*Headliner 7” Slave Monitor*Wet Okole Seat Covers
YosemiteSteve is offline   Reply With Quote
Old 11-18-2005, 11:32 AM   #2 (permalink)
baseballfanz's Avatar
Re: Pillar Spot Lights
Great job. You had the invisible man drilling the hole for you? Seeing that no one was holding the drill.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
Old 11-18-2005, 11:36 AM   #3 (permalink)
LOL Paris showed up to help again.
Interior:
Old 11-28-2005, 11:01 AM   #4 (permalink)
Thanks for the info on these.
RU2112SH is offline   Reply With Quote
Old 11-28-2005, 12:30 PM   #5 (permalink)
I just thought of a few tips if anyone decides to do this, make absolutely sure you have the right Nissan template the kit comes with 3 pages of templates and be sure to order the right or left side pillar kit. After the main shaft hole is drilled its very difficult to figure out where the inside trim hole should be drilled, keep the drill guide in place, replace the inner-pillar trim piece then heat a coat hanger with a little torch or other means and steady the wire through the hole until it melts through the plastic on the other side. Now you have an instant reference for your lamp shaft and can drill to the appropriate size.
Old 04-23-2007, 11:13 PM   #6 (permalink)
Thanks to you I did this on my F-150 Lariat. Nearly broke my wrist. Lets just put it this way, 1 speed drill with monster torque + cruise control, bit jammed into sheetmetal...it hurt. Are these H1 bulbs? I am possibly going to purchase an HID kit to put into the spotlight. I oftentimes use it as a driving light as well, along with my current HID setup (4 hids).
///SIG IMAGE REMOVED: TOO LARGE\\\
Josiah is offline   Reply With Quote
Shiny black pillar covers JHOOTITAN Titan Parts & Accessories 13 10-10-2005 06:44 AM
anyone try the PILLAR TRIMs? Birdman Titan General Discussion 14 07-25-2005 07:17 AM
Titan + metal pole + A pillar = bad day Titan4x4Aggie Titan General Discussion 25 09-23-2004 06:01 PM
knicks on pillar where seat belt hits TNTITAN Titan General Discussion 22 06-02-2004 10:25 AM
door pillar stickers kurtdb1 Titan General Discussion 2 03-24-2004 09:33 AM
