Old 11-28-2005, 10:19 PM   #1 (permalink)
Send a message via AIM to ryeguy187 Send a message via Yahoo to ryeguy187
performance suggestions?
hi my name's ryan, i'm a new member here but a long time viewer of the site. i'm also a technician at a nissan dealer and that's how i fell in love with my titan. i have an 05' titan crew cab 2wd se with all the goodies except the leather and the navi.... performance wise i have an fipk intake, flowmaster 40series exhaust with reso deletes and stock pipes, coolant bypass, ground wire kit, and 2 degrees advanced timing with the consult nissan computer run on 91 octane. i love this truck and it sure does scream but cant get enough of the power and want more... any members have any suggestions to get more outta these already sweet trucks?
ryeguy187 is offline   Reply With Quote
Old 11-28-2005, 10:25 PM   #2 (permalink)
Re: performance suggestions?
Will the ECU advance the timing by itself after a few tanks of 91 octane?
Old 11-28-2005, 10:43 PM   #3 (permalink)
the factory ecu constantly changes your timing based on many factors such as fuel and air and temperature. as far as i know your timing will not advance based on fuel alone but u might get a slight advance along the rpm range. what i did was advance my timing 2 degrees constantly above what the timing is at any rpm range which is why i require 91 octance to avoid my knock sensors from retarding my timing from poor fuel.
Old 11-28-2005, 11:10 PM   #4 (permalink)
NorCal 4x4's Avatar
The street version of the PRG traction bars will be ready soon. There is also an Off-Road version already available.
hey prg!!! questions???
Old 11-28-2005, 11:12 PM   #5 (permalink)
phillipyang's Avatar
Send a message via AIM to phillipyang
To improve current performance in the truck,
synthetic oils all around (2hp)
improve curb weight (depends on weight, every 100 pounds = .1 second)
To increase performance,
NOS system (20-100hp)
Headers (15-25hp)
Remove fan from the belt and convert into electric fans (5hp)
Custom ECU upgrade
Turbo/Supercharger setup
Nissan Titan LE 4x2 CC
Purchased: Feb 2004
Miles to date: 74,000 (Since Feb, 15 2004)
Mods: Banks Cat Back Exhaust System, K&N with arbox mod, Front Air Dam, Custom bed cover, AC/DC interior conversion, PSP/Ipod Dock
http://www.phillipyang.com
phillipyang is offline   Reply With Quote
Old 11-28-2005, 11:30 PM   #6 (permalink)
Hey Swarren1, do you know anything new regarding Deaver spring packs? I think I saw posts regarding (1) possible upgrade pack to retain stock overload leaf and (2) possible upgrade pack with minimal rear lift. Any news?
Old 11-29-2005, 03:30 AM   #7 (permalink)
NorCal 4x4's Avatar
Haven't heard anything on 1, for a quite awhile. For 2, he said it would take several weeks, but he can mod the existing ones I believe.
Old 11-29-2005, 05:35 PM   #8 (permalink)
i was talking to another tech at my dealer and he told me that electric fans actually reduce hp over the fan clutch setup.....
Old 11-29-2005, 05:37 PM   #9 (permalink)
i also have all synthetic oils and have reduced drag weight by removing spare tire and such and as far as i know by checking on here there are no real ecu upgrades that really work so far?
Old 11-29-2005, 05:38 PM   #10 (permalink)
i want to avoid installing headers because they are a pain in the butt and my truck is already very loud as it is
Old 11-29-2005, 05:39 PM   #11 (permalink)
Hmm wouldn't getting rid of the mechanical setup reduce the load on your crank directly? Less mass to travel around... less inertia?
-Cyrus
Vyrus is offline   Reply With Quote
Old 11-29-2005, 08:31 PM   #12 (permalink)
according to my co-worker.... he said the mechanical setup is better because the drag is only put on the motor when the motor needs it but when the motor is cool or at a high rpm such as in racing that the clutch disengages and the drag is no longer there. an electrical setup puts a load on the electrical system and takes horsepower that way.
Old 11-30-2005, 03:00 AM   #13 (permalink)
aluminum drive shaft would be a good bump.
juma
Old 11-30-2005, 03:34 AM   #14 (permalink)
can u actually get more acceleration from an aluminum driveshaft? and do they make em for the titans?
Old 11-30-2005, 09:09 AM   #15 (permalink)
baseballfanz's Avatar
How much would a supercharger cost you with your employees' discount? It don't get any better than that performance wise.
Titan/Armada Part Numbers
Nissan ODB2 Codes
305.5 WHP, 370.4 ft/lbs tq
just need some suggestions jree Titan Visual & Audio Discussion 13 11-17-2005 07:40 AM
Are there Any Performance Chips/Performance Modules For the TITAN? TEO314 Titan General Discussion 2 05-12-2005 09:38 AM
Maybe some suggestions? avroflyer Titan Wheels, Tires & Brakes 1 04-01-2005 01:53 PM
