Old 12-05-2005, 10:20 PM   #1 (permalink)
something rattling
their is something rattling under the frontend.it doesnt sound like anything serious like something is loose on the frame or anything its just annoying.i dont hear it unless im on the dirt road to my house.i know thats not much to go on but thats about all i have.it doesnt sound like metal on metal.never know somebody may know just wear to look
SKEET is offline   Reply With Quote
Old 12-06-2005, 06:29 AM   #2 (permalink)
EricNY's Avatar
Re: something rattling
I had the same problem, It was the right side strut. I took it to the dealer and they replaced it.
EricNY is offline   Reply With Quote
Old 12-06-2005, 07:37 AM   #3 (permalink)
there is also a new tsb out for the fan assembly - loose/rattling.
I have a similar rattle coming from the front of the vehicle. I will be taking it in for the tsb and also have them adjust hood/latch which other members have posted will fix a rattle from the front.
08 LE Desert Stone with Tow
DjKamper is offline   Reply With Quote
Old 12-06-2005, 12:27 PM   #4 (permalink)
Banned
flyguy's Avatar
Here is the TSB link for the condenser fan rattle...
http://nissanhelp.com/Ownership/Bull.../NTB05-096.htm
flyguy is offline   Reply With Quote
Old 12-06-2005, 12:49 PM   #5 (permalink)
i could not explain the sound but that is what it sounds like.it does sound like plastic rather than metal i even tried to tie the plastic under the front fender wall besause thats what it sounded like but didnt work.thanks
Old 12-07-2005, 06:19 AM   #6 (permalink)
I have an 04 SE without off-road, and the front skid pan has four of the weakest 12 mm bolts holding it to the truck I have ever seen! I had a rattle from it that only happened once in a while, when I climbed underneath, one of the bolts was loose. I tried to remove it and it had stripped and wouldn't come out. So, I had to knock it off with a chisel, and re-threaded it to a larger bolt. That was at about 10,000 miles. This past week, I changed my oil, 30,000 miles, and another one did the same thing. So, I tapped all three of them and put in 1/2" stainless steel bolts for each. The two bolts were stripped so bad you could hardly see the threads on them. I also broke the head off one of the others when I removed it. Hopefully, they didn't use these same botls for much else!
KYDeepwater is offline   Reply With Quote
Old 12-27-2005, 08:58 PM   #7 (permalink)
I also have the same problem.
wildtitan is offline   Reply With Quote
Old 12-27-2005, 11:07 PM   #8 (permalink)
Supporting Vendor (Gold)
PrerunnerGreg's Avatar
The whole truck is built with bolts like that, we call them "butter bolts" and most will gall with ease. On reassembly, we use a bit of anitsieze on jsut about everything, makes a huge difference.
something rattling when I drive/brake rcantu Titan Problems & Dealer Service 8 05-07-2005 05:21 AM
Rattling rear seats in CC TitanVol Titan Problems & Dealer Service 0 02-02-2005 02:09 PM
how do I stop my keys from rattling? Vegas04 Titan Problems & Dealer Service 24 01-28-2005 08:01 AM
Rattling Sunroof Step Up Titan General Discussion 1 09-23-2004 01:23 PM
Loud engine rattling on startup dagger Titan Problems & Dealer Service 6 09-17-2004 09:42 PM
