Old 12-14-2005, 08:24 PM   #1 (permalink)
Buzz's Avatar
Send a message via Yahoo to Buzz
MAF Failed
Did the 15k service on my Titan last Saturday at 15,053.
Sunday went to the ATM then hit the freeway to hook up with some friends. Barely a half mile on the freeway the truck lost power and went to idle. I thought I lost the rear end at first. Got her off the road and she died.
Truck would start and run a few seconds then die. Nope not the rear end. Maybe a fuel pump.
Called a tow truck and had it towed to the dealer. Got a call on Monday that they might look at it that afternoon. Told them while they had it in to maybe do the BCM recall as well if they had the parts.
They had it done on Tuesday. MAF had failed and they did do the BCM recall.
Truck barely had 12 miles on it since I did the 15k service. Guess changing the air filter must have put the MAF over the edge.
So far, so good.
2004 Smoke SE CC 4x4, AB, OR, RF, TW, UB, Banks Monster Exhaust, JetTech Helper Springs = Born on 7.8.04, Adopted 8.12.04
Buzz is offline   Reply With Quote
Old 12-14-2005, 09:43 PM   #2 (permalink)
37L1's Avatar
Re: MAF Failed
Sorry to hear that Buzz.
My guess is that failure 12 miles after the 15K service, someone at the service department, f'd up. Where did you get it done, Boardwalk?
2004 Titan Smoke LE CC
Born 11/18/03
Bed Extender, Overhead Racks
-Gambit
STUPID IS AS STUPID DOES.
-Forrest Gump's Momma
Old 12-14-2005, 09:52 PM   #3 (permalink)
Buzz's Avatar
Re: MAF Failed
Nope Lon.
Dan and I did the 15k service. Changed the Air Filter with the OEM filter bought from Boardwalk for $9.87.
Boardwalk did the warranty repair work and it runs just fine now.
I just wonder if and when I finally buy the Volant if this will happen again.
Anyone know what a MAF sensor costs?
Old 12-14-2005, 09:58 PM   #4 (permalink)
37L1's Avatar
Re: MAF Failed
Originally Posted by Buzz
Nope Lon.
They ain't cheap.
So far I have installed 3 Volant's and none have experienced MAF failure. In fact I don't recall seeing any MAF problems except for a few who had issues with the K&N.
Born 11/18/03
-Gambit
Old 12-15-2005, 12:59 AM   #5 (permalink)
TitanTech659's Avatar
Re: MAF Failed
MAF are expensive. If you add aftermarket cold air intake kits, you will more than likely pop the MAF. I've seen it many times. After market air filters cause issues and it's hard to get the MAF warrantied.
TitanTech659 is offline   Reply With Quote
Old 12-15-2005, 11:56 AM   #6 (permalink)
Armada's Avatar
Re: MAF Failed
With respect, I have to take issue with this statement. I've been running K&N cone type filters for many years on a broad variety of vehicles and have not had this happen.
Note that the failure in question occurred with a factory filter. If there had been a K&N or other oiled gauze filter on the vehicle, the dealer would have jumped on that and claimed it was the cause.
MAF's fail for a lot of reasons and for no reason at all. And, if oil ever were to be the reason for a MAF malfunction, there are tons of information in general service manuals and in Internet postings that most fouled MAF's (usually caused by exhaust recirculation in older engines) can be easily cleaned by spraying an atomized alcohol or other electric or electronic cleaning solution onto the MAF element.
Here's how you do it on the Ford modular V8 engines:
http://www.fordf150.net/howto/clean-...low-sensor.php
'04 Armada SE Offroad 4x4
Galaxy Black
K&N Drop In Air Filter w/ airbox mod
Carbotech Bobcat front brake pads at 28K miles (no brake judder, just time to change pads)
Armada is offline   Reply With Quote
Old 12-16-2005, 09:18 AM   #7 (permalink)
casique's Avatar
Re: MAF Failed
I've had my Volant installed for over a year with no problem.
2004 Radiant Silver Titan CC LE 4X4, DVD/NAV, big tow, no-offroad, Volant, tinted windows, utili-bed extender, Retrax Bed Cover, Zoomer Exhaust, Westin Bull Bar w/PIAA driving lights, Silverstars hi/low/fog, bug guard, Nissan Aluminum Diff Cover, smoke chrome grill cover and sun roof visor.
casique is offline   Reply With Quote
Old 12-16-2005, 05:41 PM   #8 (permalink)
loufish's Avatar
Re: MAF Failed
I take issue with your dealers explaination...you don't need the MAF to drive...I'll say it again, if you dis-connect your MAF, you can hop in the truck, fire it up(it will idle)and drive around.
It won't drive correctly, and may shift funny, but you will get home.
PRG Performance Kit w/SAW's
Born 9/2004
2002 Honda XR650R
Old 12-17-2005, 02:13 PM   #9 (permalink)
Re: MAF Failed
As an ASE Certified Nissan Technician, I fully understand how a MAF works and what makes them not work. I was just making a simple statement based on what I have experienced. The most frequent reason for failure, again from my experience, is an aftermarket air filter. And yes, I did see that he had an OEM filter. I do know of aftermarket filters that will not harm MAF. The ones that the customer buys to save a few bucks are usually the ones that cause failures.
Old 12-17-2005, 02:19 PM   #10 (permalink)
Re: MAF Failed
loufish is right. If you disconnect the MAF the ECM will go into safe-mode and you CAN drive it. The truck will act P'd off but it will run. But, out on the road in the middle of nowhere it's hard telling what the problem is and it is best to get it towed than to start disconnecting things under the hood.
Old 12-18-2005, 09:32 AM   #11 (permalink)
onthefence's Avatar
Re: MAF Failed
I showed up to pick up Buzz and drive him home.
As a former ASE Master Tech I too thought that a MAF failure wouldn't strand the vehicle, just as said before, it would start, the idle would drop until the engine died in about 3 seconds. Any attempt adding throttle killed the engine immediately. My gut told me it was a fuel supply issue, the dealer's paperwork says otherwise,,,,,
20 04 Silver SE KC 4X4 OR RF UB
onthefence is offline   Reply With Quote
Old 12-18-2005, 12:31 PM   #12 (permalink)
Re: MAF Failed
Yea, that is a the typical behavior for a failed MAF. It also would sound like a fuel pump failure. I would have guessed fuel pump issue as well due to having to replace a few fuel sending units for false fuel level readings in Titans. Fuel tank was empty when the gauge said it was 1/4 to 1/2 full. The truck would run for a bit then just die. I did a gauge sweep to make sure the gauge was working and it did. Went and added some fuel and could not get the truck to die. Replaced the fuel sending unit and sent him down the road. He has not had problems since. I have yet to see a MAF failure in a Titan with an OEM filter. If you would have disconnected the MAF he could have driven the truck to the shop. But how would you REALLY know it was the MAF without seeing it happen in more Titans and without a scan tool out in the field.
Old 12-18-2005, 01:38 PM   #13 (permalink)
Armada's Avatar
Re: MAF Failed
What about the guy that started this thread, took his truck into a Nissan dealer for his 15,000 mile check, got 12 miles on it after service and had a MAF failure using nothing but Nissan OEM filter?
Galaxy Black
Old 12-18-2005, 03:49 PM   #14 (permalink)
37L1's Avatar
Re: MAF Failed
He did his own 15K service and replaced the air filter with a stock OEM then after the MAF failed he took it to Nissan for diagnosis and found the MAF had failed.
Born 11/18/03
-Gambit
Old 12-18-2005, 05:34 PM   #15 (permalink)
Armada's Avatar
Re: MAF Failed
You're right and thanks for correcting me. My point is that the truck had only OEM air filters.
Galaxy Black
1st 2006 differential replaced-failed- 41 report PHOEBISIS Titan Problems & Dealer Service 43 01-30-2006 09:24 PM
Failed Diff Internals - pics Austin Titan Engine, Transmission & Drivetrain 46 12-09-2005 06:11 AM
After 4 diff's I still have no idea why they failed ccsi1@swbell.net Titan General Discussion 159 11-16-2005 05:51 AM
Have Any 2.94 Rear Ends Failed? PHOEBISIS Titan Problems & Dealer Service 11 10-19-2005 12:12 PM
Failed Dash Cluster PDX_Doug Titan Problems & Dealer Service 1 02-28-2005 02:53 PM
