LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 04-04-2007, 02:12 PM   #286 (permalink)
FuzzyLogic's Avatar
Re: Here's # of Rear Diff Failures Reported
Originally Posted by TallTexan
Not 100% certain but I think the ZH05D has the locker and the ZH04D is the non-locker.
I think you're correct.
As far as I know, there have not been any failures on the ZH05D...At least they are not on the log.
It's not rocket surgery.
'06 CC 4X4 SE Born Oct. 05
Big Tow
Eclipse GPS Navigation/DVD/CD (Dealer Option)
Smoke
World's fastest beer cooler (see photo gallery for explanation)
FuzzyLogic is offline   Reply With Quote
Old 04-04-2007, 02:18 PM   #287 (permalink)
FuzzyLogic's Avatar
Originally Posted by titan2005
my 07 CC 4x4 BT rear diff # is 43001-ZH04B and i've not seen anyone else post this part # ? i would like to know if mine has an updated rearend with the 4 spider gears or do i have the one with 2 spider gears ?
I can't seem to get a straight answer on this issue either...I've been told that it's the same unit...and I've been told there are improvements to the internal components (one Nissan mechanical mentioned additinal pinion bearings?).
I'm not sure how you could have four spider gears...how would there be any room in the diff for that?
Does any human on earth have a definative answer? This is a mystery greater than the lost continent of Atlantis (no...it's not actually in the Bahamas).
Big Tow
Smoke
Old 04-04-2007, 02:22 PM   #288 (permalink)
charliethetuna's Avatar
i would really like to know also i had mine replaced but what doeas that mean with a improved version or a new old one thats going to go again we need to get to the bottom of this
charliethetuna is offline   Reply With Quote
Old 04-04-2007, 02:42 PM   #289 (permalink)
i have reported it before when it happened but i just reported it again
Old 04-04-2007, 03:39 PM   #290 (permalink)
FuzzyLogic's Avatar
What is your original part number and the new part number?
Big Tow
Smoke
Old 04-04-2007, 04:33 PM   #291 (permalink)
i havent looked but from what it seems like everyones saying it the same rear just a new one i wish we could get i real nissan answer
Old 04-04-2007, 06:50 PM   #292 (permalink)
Attached is the latest log.
tjhack--please reply or pm me your ODI complaint # as well as your new part number.
white
whiteLE is offline   Reply With Quote
Old 04-04-2007, 06:51 PM   #293 (permalink)
TallTexan's Avatar
Nissan will not tell us what changes they have or have not made. I am afraid they have made some changes on the locker version but done nothing on the others. If they had made big changes, they would be bragging about it. We will all know when 07 Titans start loosing diffs. If that happens, used Titans might be easy to find. I can not get consumer affairs to even call me back so I can tell them the 4th diff they just installed is humming at 200 miles and the oil is greyish black. Something is wrong here.They change these diffs out too easy. They must know why they fail but they are not telling us.
Robert Louis Stevenson
Old 04-04-2007, 06:57 PM   #294 (permalink)
TallTexan's Avatar
Mine was a ZH06D, which failed shortly after I bought the truck new. The replacement is a ZH05D and it had a tag on it that showed a manufacture date of a few weeks before installation. So, as stated in another post on this thread, it dosn't appear that came from some "surplus" from Dana.
Mine has been fine ever since and now has almost 28,000 on it.
That makes sense. All the diffs they are putting on my truck are dated 10-06 but your new truck is a date close to your build date on your truck. They must be getting rid of the old problem diffs hoping some will work not caring about the customer. Something is starting to smell here.
Old 04-04-2007, 08:08 PM   #295 (permalink)
new here... reading some of the symptoms of the rear problems... are they VERY obvious? humming and such. I have 19k on my 2005 KC with a locking rear and never thought about it. I did have the brake issue, after I towed a bass boat through the mountains. dealer replaced and they are fine but have not needed to tow heavy since.
Red Ryder is offline   Reply With Quote
Old 04-05-2007, 06:51 AM   #296 (permalink)
TallTexan's Avatar
My symptoms were a whinning sound around 50-60 mph which stops when you let off the gas but happens again when you step back on the gas. When I check the oil in the diff, it is a dark color rather than the clear pink oil they put in. Check the inside of your wheels to see if you have any seal leaks. Two of mine had seal leaks. Others have had metal rattling sounds all the way up to a total lock up.
Old 04-05-2007, 09:47 AM   #297 (permalink)
DawgBone's Avatar
Originally Posted by DawgBone
I thought I was one of the lucky ones, but add me to the list as of Thursday.
Complaint #10186624
2004 4x2 SE Crew
Non Big Tow
Non Offroad
No Locker
1st Failure, happened @ 49,800 miles
No VDC
No Towing
Had 3 brake repairs
Sorry, don't have the old part #s since the truck is with the dealer, but I'll get the new ones when I get the truck back.
Got my truck back last night. New assembly part #4003-7S26A, Dana part #3786 dated 3/17/07. Sorry, I didn't have access to the old parts to get those numbers.
Old: '04 SE Crew 4x2
New: '08 SE Crew 4x2
Nov 16, 1996, UGA at Auburn, 1st quarter: UGA V almost takes Auburn wide receiver Rober Baker's manhood off for catching a touchdown pass to put Auburn up 7-0. Stupid leash.
DawgBone is offline   Reply With Quote
Old 04-05-2007, 06:22 PM   #298 (permalink)
Thanks for the heads up, I will check the seals asap. no noise that I have heard. of course, it looks like it could happen ANY time... yea...
I also saw my first set of HID's tonight... How much?? where?? Mod fever is setting in...must do exhaust, must have intake, must be spring .
Old 04-05-2007, 06:26 PM   #299 (permalink)
wow not good with this reply and quote thing yet.
Old 04-08-2007, 08:16 PM   #300 (permalink)
etalian2005's Avatar
Send a message via AIM to etalian2005
so has Nissan worked out the issue w/ the '07.
2008 PRO-4X w/ leather, RF, BT, CC, Shortbed
MODS: McCulloch 6000K HID kit, 25% front tint, 5% rear tint, 2 10" Boston Acoustics G1s, Alpine PDX-1.600 amp
Originally Posted by BKW
The problem with the 5.3 Chevys is: Their get up and go...got up and went.
etalian2005 is offline   Reply With Quote
Poll on rear end failures cttitan Titan Engine, Transmission & Drivetrain 89 12-03-2007 08:59 PM
Survey-REAR END FAILURES ONLY PHOEBISIS Titan Problems & Dealer Service 615 11-21-2007 11:37 AM
Everyone please report Rear End failures to pepco Titan General Discussion 3 01-09-2006 12:17 AM
Rear Axle seal failures Wiscdave Titan Problems & Dealer Service 4 11-22-2005 06:12 AM
