LinkBack Thread Tools Rating: Thread Rating: 2 votes, 5.00 average. Display Modes
Old 07-09-2007, 12:37 PM   #346 (permalink)
Re: Here's # of Rear Diff Failures Reported
It finally happened at about 9500 miles (I bought the truck new late last summer).
Took my 05 Crew Cab? (4 full sized doors), 4x4, off road, E lock, Big Tow in because they just did the brake recall (did new front rotors and pads and new rear pads and resurfaced rotors) and it was making a clicking noise when I hit the brakes.
They call me back and say it's the rear end and will have one in at the end of the week. Service mgr says he's seen one other in the 14 months he's been there.
Also they had to replace the aux fan. He said it was a recall on the 06's.
I tow about 3500 pounds 30 to 70 miles about 3 times per month.
From what I've gathered from this lengthy thread, it doesn't sound like my new rear end will be any better than what I've got, is that right???
jim
bigbang is offline   Reply With Quote
Old 07-10-2007, 04:24 PM   #347 (permalink)
moore101's Avatar
My rear axle started whining and gas mileage going down and the pass side seal just started leaking. The dealer is replacing it under warranty. I have submitted a case to the NHTSA #10195992
Year: 2004
4x4: Yes
BigTow: Yes
Off Road: No
Locker: No
Mileage at First Fail: 17000
# of failures: 1
Tow: Yes
Max Towed: 8400#
Hilly: Yes sometimes while towing
Brake Issues: Yes, the final fix worked
VDC: Yes
2004 Nissan Titan KC SE 4x4 with Big Tow package- Zoomers exhaust tip, Rear-view screen in sunglass pocket, scanguage intergrated into overhead console, power tailgate lock.
1982 Delorean DMC-12 Turbo (Vin #10696)
2000 Toyota Camry CNG Powered
1999 Forest River Sandpiper 21R 5th wheel trailer
moore101 is offline   Reply With Quote
Old 07-10-2007, 08:02 PM   #348 (permalink)
Good stuff--thanks moore
Attached is the latest failure log
whiteLE is offline   Reply With Quote
Old 07-12-2007, 11:35 AM   #349 (permalink)
Complaint #10196190
Year: 2005
4x4: Yes
BigTow: Yes
Off Road: yes
Locker: yes
Mileage at First Fail: 9500
# of failures: 1
Tow: Yes
Max Towed: 3500
Hilly: not really
Brake Issues: Yes - replaced front rotors and pads as well as rear pads and turned rear rotors
VDC: no
Old 07-16-2007, 10:20 PM   #350 (permalink)
Originally Posted by TallTexan
That makes sense. All the diffs they are putting on my truck are dated 10-06 but your new truck is a date close to your build date on your truck. They must be getting rid of the old problem diffs hoping some will work not caring about the customer. Something is starting to smell here.
The new diff I had intalled in my truck has a date on it of 10-06 also.Does this mean I got the same diff that was replaced?Thanks.
SKEET is offline   Reply With Quote
Old 07-17-2007, 06:43 PM   #351 (permalink)
Skeet--what was your part number prior to the current one? (43001-7s37B?--I only show you having one failure)
I wish someone with an 08' would reply with their part number as I believe they have a different part number again.
white
Old 07-17-2007, 06:58 PM   #352 (permalink)
white
Yeah only one failure I just got to thinking and wanted to know if I had one of the (supposed to be) newer rear ends or if it was replaced with the same thing it originally had.I don't know where these numbers like (43001-7s37B) are coming from because I don't have anything like those numbers on my diff.The paper work I got from the dealer ( which I don't have any more) must be where these #s are coming from.
Old 07-26-2007, 10:10 PM   #353 (permalink)
Masa's Avatar
My'06 has had 3 rear axel seal failures in 25,000 miles and now getting the whole rear end being replaced. Last week, at little over 25,000 miles, oil started leaking where the driveshaft goes into the differential housing. The tech also confirmed that there was whine heard from the rear end during his test drive. Funny things is, I was already hearing the whine not too long after I bought this Titan... I had brought it to my service writer's attention before, but his techs could never confirm it. Bright side is, I may end up with better working parking brake based on what I read recently on this forum.
'06 White 4x2 CC LE w/ Big Tow & Bench Seat
San Antonio, Texas
Masa is offline   Reply With Quote
Old 08-01-2007, 01:50 PM   #354 (permalink)
TallTexan's Avatar
Nissan has now refused to honor their warranty. My last differential went out at 59 k and now at 67 k, the new one is whinning and has a lot of play in it. Nissan will not even talk to me even though the new rear end has a 12k or 1 year warranty. Baker-Jackson South in Houston is worthless. They sell trucks but service has now become a thing of the past. New service manager and he will not even call and tell me why they don't pressure Nissan to fix my problem. I have purchased 3 Nissans from Baker-Jackson Nissan in the last 7 years. Guess customer loyalty does not exist there. Anyone with a 04 through 07 Titan should know your chances of having a diff failure is pretty good.
Having said that, I am looking for someone in the Houston-Conroe area that can install a Tru-Trac diff in my truck. I have a 2wd , 04, BT. I am not going to wait for this thing to fall apart.
Robert Louis Stevenson
Old 08-01-2007, 02:45 PM   #355 (permalink)
s3gunner's Avatar
I had the right rear axle seal replaced at 29,000 miles, said then that diff. "clunked" shifting from rev to drive (or vice versa), they changed the diff oil. After telling them that it made no change, they ordered a whole new rear end to be replaced Friday. Sounds like only my springs and wheels are going back on the rear.... (also changing the fuel sensor while they have the axle out) It should improve my parking brake as well. All under warranty... Not bad when you consider I didn't buy it from them in the first place... But I will next time!
Steven
s3gunner is offline   Reply With Quote
Old 08-05-2007, 08:18 AM   #356 (permalink)
I think what we are seeing is Nissans choice. My Xterra is sitting while legal action proceeds. There choice is, deny the design flaws, blame the customer and destroy the market.
They could have chosen to.......stop the assembly lines, determine the partys that allowed this to happen, assure no more exploding diffs are installed, take care of customers through warranty or recall, and preserve there blossoming truck market.
After 2 new Nissans in a row I know I am done, and trying my best to cost them thousands of additional sales.Both choices are expensive....I wonder which would have been better...hmmmmm.
Lloyd Swartz is offline   Reply With Quote
Old 08-05-2007, 08:55 AM   #357 (permalink)
and now at 67 k, the new one is whinning and has a lot of play in it. . . . . .install a Tru-Trac diff in my truck.
Tru-Trac replaces the oem carrier and spiders. It does not replace oem ring gear & pinion. If you have ring/pinion wear causing the whining, just a Tru-Trac install will not solve that problem.
Old 08-06-2007, 07:06 PM   #358 (permalink)
NCJeff's Avatar
What are the symptoms of the diff. failing? Or does it just go kaplooey at once? I have a 2005 that I bought last month with 28,000 miles, and I can feel a little clunk or slippage or something when I take off from a stop at normal driving. Could this be related to this, or is it something else I'm feeling, like the tranny engaging or the springs dipping? Or maybe the box shifting from all of that raw power I have never owned a Titan, this is my first. Maybe I should take it to the dealer and have somebody drive it.
NCJeff is offline   Reply With Quote
Old 08-06-2007, 07:17 PM   #359 (permalink)
DawgBone's Avatar
Regardless if it is the rear diff or not, I'd take it in. As for the symptoms, many like myself had fluid leakage around the axle seals or at the driveshaft and/or noises from the rear. Take a look at the 4th photo in this thread (the thread topic is totally unrelated) and you'll see an example of leaking axle seals:
Magnaflow exhaust installed!
BTW, welcome to T.T.!
'08 SE Crew: Superchips Cortex, Stillen Long Tube Headers, Stillen Intake, Magnaflow #94035 High Flow Cats, Magnaflow #12258 muffler swap, Motorvator TBS, Headlight Mod colormatched in K12, Power Locking Tailgate Mod, Street Scene Speed Grill, Springtech Drop Shackles
Nov 16, 1996, UGA at Auburn, 1st quarter: UGA V almost takes Auburn wide receiver Rober Baker's manhood off for catching a touchdown pass to put Auburn up 7-0. Stupid leash.
DawgBone is offline   Reply With Quote
Old 08-06-2007, 07:33 PM   #360 (permalink)
NCJeff's Avatar
I see what you mean....I think I am going to take it in to be on the safe side....it just feels funny to me...thanks for the reply, and the welcome!
Survey-REAR END FAILURES ONLY PHOEBISIS Titan Problems & Dealer Service 621 11-15-2009 09:48 AM
Poll on rear end failures cttitan Titan Engine, Transmission & Drivetrain 89 12-03-2007 09:59 PM
Everyone please report Rear End failures to pepco Titan General Discussion 3 01-09-2006 01:17 AM
Rear Axle seal failures Wiscdave Titan Problems & Dealer Service 4 11-22-2005 07:12 AM
