Basic Titan auto tranny question... - Nissan Titan Forum
post #1 of 33 (permalink) Old 12-19-2005, 08:31 AM Thread Starter
Triple S's Avatar
iTrader Score: 0 reviews
...cut me some slack here, this is the 1st auto tranny I have owned in 28 years.
In the old days there was a dip stick you could use to check the fluid level. On all my manual tranny cars it is a case of crawling under and sticking your finger in the fill hole. I checked the Titan owner's manual and all I found was 'have your Nissan dealer check the tranny fluid...'
I see under the hood a silver tube that might be the dip stick for the tranny, is it?. The end has a cap that is bolted into place and I figured I would ask here before I took that bolt out and pulled the black plastic cap. Oh, and do I need the truck hot or running or anything special before I check the fluid level?
And yes, I know, I need to spend a day and download the service manual. Maybe I can do it during the week between Christmas and New Year's.
Thanks
I'm sick and tired of all the problems...
Triple S is offline
Advertisement
post #2 of 33 (permalink) Old 12-19-2005, 08:54 AM
iTrader Score: 4 reviews
Re: Basic Titan auto tranny question...
Yes, that is the ATF dipstick. The tranny is supposed to be at operating temperature when the fluid is checked. It is a 10 mm bolt, I believe.
Oh, and you are supposed to use lint-free paper to wipe the dipstick.
bestatchess is offline
post #3 of 33 (permalink) Old 12-19-2005, 08:57 AM Thread Starter
Triple S's Avatar
Cool, thanks.
So operating temp, does the truck have to be running?
Any why in the heck would they just not incluse all this info in the owner's manual???
Triple S is offline
post #4 of 33 (permalink) Old 12-19-2005, 08:57 AM Thread Starter
Triple S's Avatar
Oh, and if I have to add any, where is the filler hole, this same tube?
Triple S is offline
post #5 of 33 (permalink) Old 12-19-2005, 09:04 AM
Yes, check w/engine running. Further details:
how do I check transmission fluid level
post #6 of 33 (permalink) Old 12-19-2005, 09:26 AM Thread Starter
Triple S's Avatar
Thanks, I keep forgetting this forum actually has a search engine that works...
I put my latest questions in that thread.
Triple S is offline
post #7 of 33 (permalink) Old 12-19-2005, 11:23 AM
I think the reason there is a bolt on the trans fluid tube is so people don't get it confused with the motor oil dip stick tube because they are kind of close together under the hood. Check it the same as any other automatic trans- level vehicle, warm fluid, transmission in neutral and engine running. This crap about having the dealer check it is rediculous!
2Titans is offline
post #8 of 33 (permalink) Old 12-19-2005, 11:34 AM
Clint's Avatar
I spoke to my friends son. He is a Saturn technician and they do it the same way.
It is a service dept. item to be checked. Look in your owners manual. They don't make any reference to checking it do they?
Clint
You have two choices in life:
Clint is offline
post #9 of 33 (permalink) Old 12-19-2005, 04:02 PM
Has anyone used any transmission fluid other then the OEM fluid, and if you have any results. I would like to use some type of synthetic fluid, on the next change.
Thanks
johnabyrd is offline
post #10 of 33 (permalink) Old 12-19-2005, 05:50 PM
scr38's Avatar
The Nissan fluid is the only one approved by Nissan at this time. Changing to another fluid will probably void the warranty on the transmission.
scr38 is offline
post #11 of 33 (permalink) Old 12-19-2005, 06:07 PM
vuaccordla's Avatar
Send a message via AIM to vuaccordla Send a message via Yahoo to vuaccordla
I believe that bolt that locks the dipstick in place is marked so that no one tampers with it. Maybe by doing so you may have just given the dealer one more reason to say that they will not warranty your transmission.
vuaccordla is offline
post #12 of 33 (permalink) Old 12-19-2005, 06:16 PM
Valvoline says its stuff will work. Me, I'm going with Nissan Matic J:
http://www.valvoline.com/products/Maxlife%20ATF.pdf
post #13 of 33 (permalink) Old 12-19-2005, 06:17 PM
Mr. B's Avatar
iTrader Score: 1 reviews
....Bolt marked?.....and I thought that I was the only paranoid conspirisy freak......now I'm gonna lose sleep worrying about that darn dip stick tube because I've check the fluid a half dozen times or so.
SexySilver 2004 XE KC, Magnaflo, K-N drop in, butchered stock box, 18" 6 spoke LE wheels and Goodyear SR-A's, 80k miles
Mr. B is offline
post #14 of 33 (permalink) Old 12-19-2005, 06:17 PM
SarkaZm's Avatar
Thanks
Yes, as scr38 said DON'T DO IT! It must be the Nissan fluid or your warranty will be voided. I asked about it when I lost all my tranny fluid, the tech said it must be the Nissan fluid..Automati J type, or something like that.
SarkaZm is offline
post #15 of 33 (permalink) Old 12-19-2005, 06:20 PM
vuaccordla's Avatar
I'm a mechanic for a living and I want to check it so bad, but when I notice that it had a bolt and marked, I know not to touch it. They don't put bolt on the dipstick unless there is a specific reason. First time I seen it on a vehicle.
Quick Reply
Message:
Options
Register Now
User Name:
Password
Password:
Confirm Password:
Email Address
Email Address:
OR
Log-in
Human Verification
Jump to top
Linear Mode Linear Mode
basic auto mechanic books Brando7 Off-Topic Discussion 14 12-16-2005 04:40 PM
Auto headlights question Jeostang Titan General Discussion 6 08-26-2005 11:03 PM
Tranny Question SWTXTITAN Titan General Discussion 7 07-29-2005 07:55 PM
tranny question dilleyoshemp Titan Engine, Transmission & Drivetrain 5 02-18-2005 05:51 AM
Auto tranny dip stick bkaba Titan Interior Discussion 4 12-07-2004 05:29 PM
You may post new threads
You may post replies
