Old 12-27-2005, 05:58 PM   #1 (permalink)
Any rear-end failures with "helper springs"?
I don't know if this has been addressed, but there are some posts suggesting that wheel hop and axle wrap could be a contributing factor to the rear end failures. Any failures with Titans with the various helper springs?
jeff7777 is offline   Reply With Quote
Old 12-27-2005, 06:13 PM   #2 (permalink)
sonnytimes's Avatar
Re: Any rear-end failures with "helper springs"?
Nope. No helpers on mine either time.
And the daily beatings will continue until morale improves.
Or until you figure out how to use their system against them.
04 LE 4X4 OR
05 and 06 Rear ends....
05 Bed, front seats, AC parts, brakes, window reg., .....
sonnytimes is offline   Reply With Quote
Old 12-27-2005, 06:24 PM   #3 (permalink)
I changed the gear oil at 5,500, swapped to the PML cover, added helper springs early on. No rear differential problems so far at 31,000.
Old 12-28-2005, 04:16 AM   #4 (permalink)
Same here... Helper springs put on at 7k. Finned cover at 18k. Gear oil changes about every 5k. Now close to 30k. Only diff. problem is an axle seal is starting to leak. I have about 5000 miles worth of towing items from 3k to 9k lbs.. Yet I must admit I'm very gentle with my truck, no need to show off..
KenedyTXTitan is offline   Reply With Quote
Old 12-28-2005, 04:22 PM   #5 (permalink)
grunge311's Avatar
I don't think there are any rear end problems from female drivers either, doesn't mean you should get in line for a sex change.
grunge311 is offline   Reply With Quote
Old 12-28-2005, 05:25 PM   #6 (permalink)
Very true grunge311! There is no true scientific method involved in the question, although if there were a number of failures using helper springs, then I may be concerned that it may make the problem worse... If there are no failures at all when using extra springs, it may be slightly relevant toward the positive. Also, on a side note, female drivers may drive the truck a bit less agressively on average and may not have many failures, so that could have some relevance also (certainly not worth a sex change though!) LOL!
Old 12-28-2005, 05:30 PM   #7 (permalink)
gr8titan's Avatar
Installed finned cover and filled with synthetic oil at 3,000 miles. Now just installed helper springs plus traction springs. No problems so far and I visit the track often. The Titan has now 16,000 miles.
I think most of the rear end failures are a mostly (if not all) "stock" suspension equipment.
gr8titan is offline   Reply With Quote
Old 12-28-2005, 06:13 PM   #8 (permalink)
Blue_Water_Rush's Avatar
I've had the helper springs on my truck since 4,300 mi. and now have close to 13,000 mi. No problems with rear as of yet. My truck (05 LE) came with the finned cover and synthetic gear lube, though I replaced it recently with supertech 75w140 synth. The fluid level prior to that, however, was OK and within spec. Old oil was very clean. That was with 10,500 mi.
A bad day of surf is still better than a good day at work
'05 LE Deep Water Blue/ 4x4/ Off Road/ Big Tow/ Spray In Liner/ Utilitrac
COSMETIC: Undercover Lid/SS Door Accents & Fuel Door/Chrome Tailgate Trim/Dunder Web Grill/Silverstar Headlamps/Volant LED Tail Lights/LED 3rd Brake Light/LED all Int & Ext Lights/ LED Multicolor Interior Accent Lighting/Silblade Wipers/Painted Engine Cover
ENGINE: K&N 77 CAI/Banks Exhaust/AT Grounding Kit/TB Coolant Shutoff/Eco 2 Fuel Vapor Enhancer/Uprev Osiris Tuner & Cipher Software
A/V: Kenwood XXV-01D/JL Audio Amps & 10W7 Sub/MB Quart Spkrs./Sirius Tuner/KK Wiring/SSA Full Sound Deadening/Kuda PDA Base/Laptop GPS with Ram Mount/Tablet DVD with Ram Mount
SUSPENSION: 6" PC Lift/Radflo Coils/3" Deavers/1" Blocks/Bilsteins/PRG Traction Bars/Helo Wheels/PC X Terrain 35x12.50
Blue_Water_Rush is offline   Reply With Quote
Old 12-28-2005, 06:47 PM   #9 (permalink)
Send a message via Yahoo to bfiii12
I have a little over 38k and have done nothing to my rear end. No problems to speak of yet.
'04 Titan Smoke
4x4 Off Road
MODS:
Vent Visors
Delta Tool chest
PRG Leveling Kit
Lund Bug Deflector
bfiii12 is offline   Reply With Quote
Old 12-28-2005, 06:53 PM   #10 (permalink)
No problem here. 12000 miles.
PRG 2" front lift. 1" rear drop shackles
Wet Okole Front seat covers
Herbpov is offline   Reply With Quote
New pics of front 2", rear Deaver springs/bilsteins JayDee Titan General Discussion 13 08-28-2005 08:10 AM
Helper springs or ??? stefnch Titan Parts & Accessories 1 04-19-2005 05:26 AM
Helper Springs lowers rear end how much? RGV Titan Titan General Discussion 6 04-10-2005 04:30 PM
Hellwig Helper Springs Rotorheader Titan Parts & Accessories 0 04-05-2005 06:33 PM
helper springs grpape Titan Performance Modifications 0 01-22-2005 11:12 AM
