Old 01-05-2006, 02:59 PM   #16 (permalink)
Luckyontheducky's Avatar
Re: Nissan Remote Starter
Originally Posted by HudsonValleyTitan
Ours too usues the factory keyfob to start. You just hit lock twice to start. If installed the right way, you can roll down the windows or, in my case, open the power sliding doors in the Quest, without having to have the key in the ignition. The unit should be up under the dash close to the fuse panel. You can also just call the dealer to find out the brand they use.
Dealer says it is a Nissan! Doesn't roll down any windows either.
Luckyontheducky is offline   Reply With Quote
Old 01-05-2006, 03:04 PM   #17 (permalink)
HudsonValleyTitan's Avatar
Nissan doesn't make such a unit. If they did, you'd be able to order it as a factory option. If you can't hold down the unlock button to roll the windows down while started with the remote (and before putting the key in and turning it to "ON"), they left a jumper off during the install. There's an extra wire needed during the install that my dealer told me about when we had it put in the wifes Quest. The reason I know this is because we had it in the last Quest (that Nissan replaced...long story) and when it was installed in the new 05 Quest we were able to operate the power liftgate, sliders and windows. We couldn't do that on the last Quest.
- Joe
Old 01-05-2006, 03:13 PM   #18 (permalink)
I am wondering if there is a way to disable it while working under the hood so 'accidental' starting is not possible.
Old 01-05-2006, 03:18 PM   #19 (permalink)
Yes. Scoll up and read posts 1 and 3.
- Joe
Old 01-05-2006, 03:27 PM   #20 (permalink)
Just called the dealer again. They said there is no way to disable it. No switch at the fuse box. Works with the hood up. Guess I'll have to find the module and determine the brand. The one I installed on the T-Bird (Bulldog Security) had both a hood switch and a lead that disabled it when grounded.
Thanks!
L
Old 01-05-2006, 03:32 PM   #21 (permalink)
pi3yeargrad's Avatar
Thanks!
L
ye if the dealer installed they should have used that hood pin...thats a safety mechanism...
...there u old geezers...now STOP COMPLAINING!
pi3yeargrad is offline   Reply With Quote
Old 01-05-2006, 03:42 PM   #22 (permalink)
Maybe they installed one of these...
http://cgi.ebay.com/ebaymotors/Nissa...25301418QQrdZ1
Old 01-30-2006, 03:29 PM   #23 (permalink)
Well, I found the damn thing. I finally had time, daylight and good weather, which rarely happens in my life. There it was, a nice little microswitch under the steering column. It wasn't labeled or anything. I guess the mechanic is keeping it a secret! I went ahead and put a label under the hood and on the switch.
L
Old 01-30-2006, 07:04 PM   #24 (permalink)
L
I hate to say I TOLD YA SO! lol
- Joe
Old 01-30-2006, 07:33 PM   #25 (permalink)
mmmmm, yes. Except you said it was near the fuse box (thats on the passenger side)! I am just disappointed that the dealer did not inform me (in fact they said it did not even have a switch) or label it. DEALERS!!
Cheers!
L
Old 01-30-2006, 11:50 PM   #26 (permalink)
Supporting Vendor (Gold)
Dealers suck ***...lol.. The only problem I see with having a remote starter work through the key fob is the range would stink. I like the ability to start mine from couple miles...LOL
Front Stage Amp: Mmats SQ2175
Front Stage Amp: Arc Audio 2500XXK
KnuKonceptz hardware
Dynaudio "Authentic Fidelity"
a select few."
Old 01-31-2006, 06:53 AM   #27 (permalink)
Cheers!
L
True. I also said to ask the dealer where they put it because it can be anywhere. Ours is right there when you open the little access panel forhe fuse block in our Quest. That hides it nicely. You can also have it installed through the plastic so its reachable without having to remove any panels...as long as it was in a hidden spot so it wouldn't look like crap, that would probably be th best for placement.
- Joe
Old 01-31-2006, 11:45 AM   #28 (permalink)
I DID ASK THE DEALER!!!!
lol, this IS a fun one!
Old 01-31-2006, 08:13 PM   #29 (permalink)
I know you did, which is what I found funny!!! They told you there was no such switch yet they did, in fact, install one. Scary
- Joe
Old 02-01-2006, 06:54 AM   #30 (permalink)
The one I installed connects to the battery with an inline fuse about 12 inches from the battery.I always pull that fuse to be safer when I had to go to the dealer.
40Niner is offline   Reply With Quote
Remote start with Nissan FOB or aftermarket FOB? QuickOne Titan General Discussion 12 12-29-2005 10:54 AM
Remote Starter BiXLL Titan Parts & Accessories 23 10-31-2005 11:15 AM
Who has a remote starter??? PuvMan Titan General Discussion 9 05-24-2005 03:21 AM
Starter replacement alw Titan General Discussion 9 04-12-2004 10:17 PM
Adding a NISSAN keyless remote Steveoh Titan General Discussion 3 03-25-2004 07:26 PM
