Old 01-06-2006, 11:09 AM   #1 (permalink)
HemiHunter's Avatar
12 Volt Bed Outlet
My 12 Volt outlet in the bed of the truck isn't working. Does anybody know where the fuse is located? I have checked the dash but everything looks good there.
04 KC 4x4 Galaxy Black
7" CST Lift, MX-6 Rear Shocks, PRG Sway Bar End Links and 4x4 Traction Bars, BFG A\T on Centerline Wheels. Radflow Coil-Overs.
Clarion Monitors, Eclipse DVD, Kenwood H\U,Sirius Satellite Radio
HemiHunter is offline   Reply With Quote
Old 01-06-2006, 11:20 AM   #2 (permalink)
BLKingTitan's Avatar
Re: 12 Volt Bed Outlet
HH,
Check under the rear bumper on the drivers side. My outlet wasn't working either, and I found that they had not connected the connector under there. I plugged them together and amazingly, it works now. QC seems to be a lost art.
Rob
'08 Pro-4X LWB Galaxy Black 4WD
Tow, Utility Bed, Rockford Fosgate
Captains Chairs,
PRG mini lift
Zoomers Cat-back exhaust
Hatchie Bottom Max-4 camo seat covers
Nissan Bug Guard
Chrome Nissan Running Boards
Husky Liners
Nismo CAI
Active Tuning Grounding Kit
Eco-3
5000K HID Low Beams
and
'05 SE KC Galaxy Black
Big Tow,Off-Road, Utility Bed
Rockford Fosgate
Captains Chairs
Nissan Bug Deflector
Husky Liners
PRG Mini Lift, Chrome Tailgate Trim, Billet Grille
Window Tint
Leer 100XQ Shell
Extend-A-Fender Flares w/Factory Mud Flaps
Hatchie Bottom Custom Fit Max-4 Camo Seat Covers
Zoomers Cat-Back Exhaust
NISMO CAI
5000K HID Low Beams/ Silverstar High Beams
Active Tuning Ground Kit
BLKingTitan is offline   Reply With Quote
Old 01-06-2006, 11:27 AM   #3 (permalink)
HemiHunter's Avatar
Thanks...I'll check. It was working then quit. Used too many amps and probably blew the fuse.
Dealer giving me the run around, I'm sure they want me to bring it in so they can make a buck.
Old 01-06-2006, 11:32 AM   #4 (permalink)
If the fuse is not in the fuse compartment in the passenger side dash, then it is probably in the box under the hood.
Old 01-06-2006, 11:35 AM   #5 (permalink)
HemiHunter's Avatar
There's lot's of boxes under the hood. Look like relays in the one by the battery...hummmmmm.
Old 01-08-2006, 01:08 PM   #6 (permalink)
HemiHunter's Avatar
So nobody knows where this fuse is located?
Old 01-08-2006, 01:18 PM   #7 (permalink)
pi3yeargrad's Avatar
if its not in the passenger side inside the cab it is under the hood in one of those black boxes (near windshield) by battery... just pop off the covers and read the names of the fuses...
...there u old geezers...now STOP COMPLAINING!
pi3yeargrad is offline   Reply With Quote
Old 01-08-2006, 01:41 PM   #8 (permalink)
grunge311's Avatar
The one that seems like its too far back there to be a fuse box is in fact a fuse box. Thats where you'll find it, behind the battery there is a relay box, behind that is a box that noone in there right mind would make out to be a fuse box. That one is the fuse box.
grunge311 is offline   Reply With Quote
Old 01-08-2006, 01:49 PM   #9 (permalink)
ye just went to check the truck so I could tell this guy cuz if ur backp lights ever go out there is the fuse for those as well...I had to change out the fuse a couple weeks ago for the reverse/backup lights...
Old 01-08-2006, 05:14 PM   #10 (permalink)
cttitan's Avatar
It should be fuse #28 under the hood on the passenger side in the fuse and fusible link box.
Silver 4x4 SE CC, Born 3/04
Graphite Titanium
Off Road/No Locker, BIG TOW/VDC
Step Rails, Truxedo,
Gibson Cat Back, AEM Brute Force CAI
Hood Protector, Tinted Windows
My other car is a diesel
(02 VW Jetta TDI, 49 MPG)
Rockwood 2306 Travel Trailer
Equalizer Hitch, Prodigy Controller
cttitan is offline   Reply With Quote
Old 01-09-2006, 07:33 AM   #11 (permalink)
HemiHunter's Avatar
Thanks alot fellas I will check it out!
Old 01-09-2006, 08:39 AM   #12 (permalink)
Is it the one marked "RR Socket" on the cover of the fuse box?
BayouTitan
4X2 SE Radiant Silver
Popular Package
Utility Bed Package
Born on 12/03
12v power outlet tshank Titan General Discussion 5 09-18-2005 02:25 PM
What do you plug into your utility bed power outlet? atcNick Titan General Discussion 35 06-23-2005 01:27 PM
short in power outlet in console orvena Titan General Discussion 4 02-07-2005 05:38 AM
Console Power Outlet karlconnell Titan General Discussion 2 02-17-2004 06:01 PM
