Old 01-11-2006, 10:40 PM   #1 (permalink)
Wierd Sound
I am getting a wierd, mettalic "clink" sound now and then. Some times it occurs when I hit a bump. Some times during braking. Some times when I back off the throttle and coast. Some times when backing up. It is hard to isolate. I can't tell if it is from the front or rear. It just sounds like a metallic "clink". Not a whine, or consistant growl. Is my diff. letting go? Did my installer do something wrong with my PRG kit? Brakes?
rico387 is offline   Reply With Quote
Old 01-11-2006, 10:53 PM   #2 (permalink)
Vegas04's Avatar
Re: Wierd Sound
do you have helper springs in the back? the u-bolts I installed on the leaf springs worked loose over time and occasionally made a metallic noise.
Galaxy Black 2004 Titan XE CC 4x4 w/ Off-Road Package, Preferred Package.
Mods: PRG Spacers, 17x9" Eagle 187s (+2mm offset) w/ 315 70-17 BFG All-Terrain KO tires, Stillen Diff Cover, Alpine Type-R components in the front, coax. in the rear w/ 50 x 4 Rockford Fosgate Amp, XM, Debadged, and Homemade RCA pre-outs on in-dash changer.
Vegas04 is offline   Reply With Quote
Old 01-12-2006, 05:26 AM   #3 (permalink)
EricNY's Avatar
Re: Wierd Sound
I had the same problem after i got my PRG lift put in. It turned out to be the front right strut went bad , I think the guy who installed it beat on it to much when putting the strut back in. I would take the lift out and bring it to nissan and have them fix it. If they see the lift in there they will give you a hard time and probably void your warrenty on your suspension.
EricNY is offline   Reply With Quote
Old 01-12-2006, 10:40 AM   #4 (permalink)
Re: Wierd Sound
Stock rear springs. If it turns out to be the struts I'm sure the dealer will balk at the PRG kit.
Old 02-25-2006, 12:23 PM   #5 (permalink)
Re: Wierd Sound
It's been over a month since I started noticing the sound. Since I had it at the dealer for an electrical issue, I had them look at it. They said they ordered covers for the leaf spring clips. We'll see what they are when they put them in. They also did a 4-wheel brake job, modded the fan bracket, replaced the trailer harness, and ordered parts for the gas barfing filler neck. Sounds like a big day for a 4600 mile truck.
Wierd feeling on takeoff oktex88 Titan Problems & Dealer Service 38 08-17-2006 12:34 PM
Wierd Warning Lights Zoback Titan Problems & Dealer Service 5 11-21-2005 07:57 PM
wierd noise ?? P's Titan Titan General Discussion 6 11-14-2005 06:06 PM
Wierd day at the movies... CI338 Off-Topic Discussion 3 03-26-2004 09:46 PM
