Bought a 2006 CC 2wd LE in November. I have had no problems except sometimes when the back doors are closed they make a weird noise. I thought it might be the door hitting the seatbelt, but no. It kinda sounds like the window hitting metal. Has anyone else had this problem? If so, has anybody had this fixed?
BTW- I have the new color Granite. It is a great color. Getting the PRG leveling kit from Greg this weekend!
2006 LE CC, 2WD, Granite, Born 8/05, PRG leveling kit, OEM 6 spoke rims chromed, So. Cal.
Yes, I've heard that noise from the rear door behind the driver. I've only had my truck for 3 weeks and it only happens sometimes. Your description is right on. Not sure what it is, but so far I don't see it as an issue that requires a repair. The difference may have to do with air pressure or whether or not other doors are open....not sure. I'll just keep an eye on it for now.
Chris, 06 Titan Granite CrewCab LE 4X4
My 05 CC makes the noise too. I think it sounds like glass on metal. Next time I'm out there I'll try it with the rear window up, half-down and all the way down to see if that has any effect.
__________________ Chris
05 Blizzard LE CC, 4x4, BT, OR, Nav, AB, Sunroof, XM, Ceramic Pads on new rotors & hardware (10.2k+miles,no brake issues to date and very clean wheels), AutoExtreme TBS, TB coolant bypass, Inverted helper springs, Hi-capacity diff cover, Active Tuning ground kit, poly swaybar bushings (front), Axle Vent Mod
I get the same sound. Every time my daughter gets out at school in the morning I turn my head thinking the seatbelt got caught but it's not.
Clint
You have two choices in life:
